E-Class (W211) 2003-2009
Air con temperature control not functioning
Old Jan 31, 2013 | 11:07 PM
mdakdel's Avatar
E200K-W211
Hi Folks,
I am not able to control the air con temperature by the control ***. The temperature gets very cold despite a warm setting. Does any one know how the temperature is controlled? The car is MB E200K-W211 (2006 model).Appreciate your help!
Old Feb 1, 2013 | 06:29 AM
jimbo1763's Avatar
2007 E350 Sedan
Very well may be the temperature control valve. See the following.
https://mbworld.org/forums/e-class-w...rol-valve.html
Old Feb 1, 2013 | 08:40 AM
vettdvr's Avatar
03 E500 and Corvette
Common problem replace the valve.
Old Feb 2, 2013 | 05:33 AM
mdakdel's Avatar
E200K-W211
Air con temperature control not functioining
Many thanks to those who replied to my problem mentioned above. Before I attempt to change the valve (have to DIY), just need to know the workings of this valve. Does this valve respond to the temperature setting knobs? Is there any other sensors involved in the control circuit? Appreciate input to these questions.
Old Feb 3, 2013 | 04:32 PM
apl175's Avatar
The valve is not directly controlled by the temperature setting knobs. There are more than 50 sensors, actuators, valves, motors and control units that play some role in maintaining temperature inside the vehicle.
The advice to replace this valve is based on symptoms and failure statistics within this forum.
It is very difficult to pinpoint a failure definitively without the proprietary equipment.
