E-Class (W211) 2003-2009
Conversion- Digital Ac Control Unit
Old 07-27-2014, 05:13 AM
  #76
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
Originally Posted by Mackhack
The question remains: why not using a ThermoTronic unit and knowing everything will work? Sure it has more buttons and some won't do anything but who really cares?
I do. The later version looooooks way better for sure but id rather have buttons and knobs that actually do something when i push/turn it. But, its just me.
Old 07-27-2014, 06:05 AM
  #77
Drag0na5h's Avatar
2006 E350
Neither! Just trying to help. If it's not needed, let me know and I'll focus on more important **** in my life. You have to understand that certain things just can't get accomplished on these cars as much as we'd like to though. I'm playing around for more than a year to build a can bus module to do something for me that MB never intended to be on board but would be a neat feature for these cars. So far no luck, but not bc I' unable to build the herd and software but rather bc MB messed up when they developed the W211. Same thing with what we're doing here. Some MY just seem like they don't like a certain AC control unit with LCD which some of you like to have, and at the same time another one would work plug and palsy but doesn't have dial knobs for temp control.
First off, never did I brush off the facts you and Plutoe kindly laid out for me. I truly appreciated knowing that information. But additionally I was trying to narrow down to that same conclusion via member experience. Hence showing the wiring harness, which was confirmed to "look" identical on a 2005 e320.
Old 07-27-2014, 01:41 PM
  #78
Stuttgarten's Avatar
'13 E350 . M276
Originally Posted by Kushp14
Was finally able to do this and can confirm it is plug and play... I swapped with a unit from a 2009 E350.
The updating has worked on more than one car using facelift units. For Kushp.. it was plug and play, for me it was resetting system, and for Crafty, he wrote it worked for him too. What is mysterious here, is that Kushp..'s car is an '06, same as Drag...'s, but one was plug and play and the other has yet to actuate.
One big drawback to the LCD unit, is that in direct sunlight, the screen gets drained and you can't see much. This does not happen with analog stock unit.
Old 07-28-2014, 05:18 AM
  #79
Drag0na5h's Avatar
2006 E350
To clear this theory up, I'm looking to acquire a 2009 e350 unit of the same look, but with the same part number as Kushp14's "2118303290". If it works plug and play like it did for him I would conclude that the facelift 2 zone unit from MY07&08 would work on e320s MY03-05 while the facelift 2 zone unit from MY09 would work on e350s MY06.
Old 07-28-2014, 05:22 AM
  #80
Drag0na5h's Avatar
2006 E350
Originally Posted by Craftysince86
i used this unit the first time i retrofitted and mine worked, just not as pretty as the other units so i bought the newer one.
Crafty, do you recall if the part # on your unit matched the one I current have? Or is it a different part # than 2118302490?
Old 07-31-2014, 10:29 AM
  #81
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
FWIW, I just replaced the HVAC controls on my 06 CDI with a unit from a 2007 E63. Part #2118302485
Plug & play
Old 07-31-2014, 03:59 PM
  #82
Drag0na5h's Avatar
2006 E350
Plug & play
Fan of the "MAX COOL" button.
Old 08-05-2014, 06:15 PM
  #83
beejAMG's Avatar
Got this in the mail yesterday. Will try to install and report back as soon as possible...
Conversion- Digital Ac Control Unit-847db64c-0a6a-448c-bd8b-befd3f4c42f9_zpsgx2flbsd.jpg
Old 08-06-2014, 05:05 AM
  #84
beejAMG's Avatar
I got to install mine today, thanks Dragona5h for the detailed DIY and pics, luckily it was plug and play. All buttons work and i still have the "Rest" button.
Old 08-06-2014, 10:25 AM
  #85
Drag0na5h's Avatar
2006 E350
Good deal. What does the front of your unit look like?
Old 08-06-2014, 07:29 PM
  #86
beejAMG's Avatar
Sorry for the crappy pic but...
Conversion- Digital Ac Control Unit-75b89796-dbd8-4494-b4fa-7c4e9a7c43bc_zpswzgloiy0.jpg
Old 08-07-2014, 12:44 AM
  #87
beejAMG's Avatar
A better pic...
Conversion- Digital Ac Control Unit-8cfd9622-86fd-4447-a984-8c1db13ca06b_zpsipsoppaa.jpg
Old 08-07-2014, 02:18 AM
  #88
Drag0na5h's Avatar
2006 E350
Looking good man! Glad everything works too!
Old 08-07-2014, 03:07 AM
  #89
beejAMG's Avatar
Cheers mate! Hows yours working out, figured out a way around the AC button yet?
Old 08-07-2014, 04:46 AM
  #90
Drag0na5h's Avatar
2006 E350
Unfortunately not yet, but I'm having a local shop see of they can do some retrofit coding. In the meantime I'm sitting on my thumb.
Old 08-07-2014, 04:50 AM
  #91
beejAMG's Avatar
Goodluck mate! Hope you get it sorted out! The one i bought on ebay was really cheap coz it has a scratch on the plastic screen. Theres another item im lookin at which is more acceptable but im afraid i might run into the same problem as you did. So for now ill probably settle with this. All buttons are functional, thats all i need.
Old 12-05-2014, 02:04 AM
  #92
integrale's Avatar
w211 320 sport
Hello,
I want to replace my old panel for climate control with dual zone with part number 2118303190. Put new, take out the old, but the air conditioner even in the off position remains activated. Is there anything that should be coded with the diagnostic equipment or retrofit is impossible
Old 12-10-2014, 08:49 PM
  #93
Drag0na5h's Avatar
2006 E350
Originally Posted by integrale
Hello,
Your situation is exactly opposite of what I experienced when I tried this swap. My ac light nor compressor would ever turn on. All it would do is blink 3 times and remain off. I thought getting a different part number that Kushp14 tried in his similar year E350 would work. Unfortunately it did the same thing as my first part and failed to activate the AC. One theory I have as to why my two parts did not work is that they were removed from donor vehicles AFTER the ac controller recorded a fault in the AC system. Perhaps they were both from cars with frontal damage that impacted the AC system. Because of this, the fault stays with the AC controller until it is remove/reset electronically. I believe this can only be done with a Mercedes compatible computer. This could explain why some members have had success and others like myself did not. It's also not the ONLY reason for incompatibility issues. I can confirm my first unit did not work in a second E350 either, so as I said before, the fault stays with the unit. Additionally, before removing my original AC controller I had the car running and AC turned on. I could hear the compressor running during this times. When I disconnected it the compressor continued to run until I plugged in the replacement AC controller. Once I did that the AC compressor and the cabin fans immediately turned off completely. Good luck with your experimentation.
Old 12-25-2014, 04:06 AM
  #94
integrale's Avatar
w211 320 sport
If someone is willing to put the facelifted control can write to me , i have two modules for selling
Old 08-03-2015, 10:20 AM
  #95
Alie320cdi's Avatar
Mercedes e320 cdi w211
Climate control retrofit
Thanks for the help I know fitted digital climate control to my car but the ac button flashes few times and don't work
Old 03-30-2016, 09:17 AM
  #96
Obnoxio's Avatar
W211
Facelift ac control unit dead after retrofit? Try changing this setting:
xsever (05-01-2020)
Old 06-25-2017, 11:00 PM
  #97
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
My car is a 2005 E320-CDI w211.026 w/ analog AAC dual zone control unit. I bought this one off ebay & plan to install soon. I have STAR & am hoping I can code variant this unit to work for me.
xsever (05-01-2020)
Old 06-25-2017, 11:11 PM
  #98
Mackhack's Avatar
Version code it and delete the (possible) faults from the donor car, 12 faults or so will return since you don't have the 4-zone flaps, actuators, 4-zone sun sensor, and air quality sensor in your car with 2-zone A/C. If you want to do a proper job, take your dash out and replace the entire A/C box. It's definitely worth the work.
xsever (05-01-2020)
Old 06-26-2017, 01:20 AM
  #99
That task looks a little beyond my scope I'm afraid. 12 DTC will be permanently set using this unit, eh? Looks like I need to track down one that's not a quad zone unit.
Old 06-26-2017, 08:53 AM
  #100
Mackhack's Avatar
I know that video. He takes more off than necessary like the center console.
You can can buy a face lift unit with display. There are diffiferent versions. Some will work in your car some won't. You would have to try different ones, too.
Quick Reply: Conversion- Digital Ac Control Unit
