E-Class (W211) 2003-2009
active lights inoperative.
Old Feb 7, 2013 | 10:23 AM
edusyl's Avatar
2006 mb e350-,2019 glc amg43
For a while i'm being getting this message active lights inoperative, but the lights works OK, they go up and down and turn when i'm driving. It doesn't do it all the time. Both batteries are new, but this didn't change anything.
I going to take the car to service,but before I do that i would like to have some ideas.
2006 E350 with 48000 miles.
Old Feb 10, 2013 | 06:05 PM
starbrite's Avatar
2004 E320
When you changed the main battery, you have to reset several things, windows, sunroof, etc. One of those items is the active headlights. Turning the steering wheel lock to lock does it.
Old Feb 11, 2013 | 08:04 AM
edusyl's Avatar
Thank You, I will try it later on.
Old Feb 14, 2013 | 01:14 AM
Kropf's Avatar
2005 E55 Black, 2007 GL450 Carneol Red
Smile
Any more details for this reset? i.e.
Ignition in '2' (engine running)?
Headlights on?
Can car be moving (hope so to avoid griding flat spot on tires)?
My Datacard shows:
615 BI-XENON HEADLIGHT W.ACTIVE CURVELIGHT RIGHT-DRIVE
But I've never seen mine move left or right, only up and down.
And I have never seen any error messages as noted by the OP.
(I'm wondering if one or both of my active headlights were replaced with non-active lights after her 2007 accident.)
Old Feb 14, 2013 | 07:48 AM
edusyl's Avatar
Ok, I tried the lock to lock steering and didn't work!
I did it with the engine running and the lights on.
And Yes, I can see the headligts turning a little when I go over 30 mph
Old Feb 14, 2013 | 04:17 PM
starbrite's Avatar
2004 E320
Sorry, I should have been more specific.....drive slowly and turn lock to lock. Lights off.
Old Feb 15, 2013 | 07:31 AM
edusyl's Avatar
Thank You Starbrite, I will try again today.
Old Feb 18, 2013 | 05:52 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
If it is intermitent it could also be one of the motors inside the lamp has a bad wire.
Dealer fix is new headlight ***. but you can open them up and rewire for $5; catch is you if you don't know exactly whats wrong you will need to rewire the hole 4 motors.
You can pay for a diagnosis and that will tell you exactly what motor on what side it is.
Old Feb 19, 2013 | 07:39 AM
edusyl's Avatar
I tried going slow, going forward and in reverse doing lock to lock but it didn't work.
Now the inoperative headlights comes on every time I start the car, but the headlights do go up and down and turn when I'm driving.
