E-Class (W211) 2003-2009
Smoke out of exhaust above 5,000 rpm (E550 4matic)
Old Feb 13, 2013 | 10:45 AM
WildWolf's Avatar
2019 E63s
Can anyone tell me why I see gray smoke coming out of my tailpipes when I am on the throttle above 5,000 rpm? Dealer said nothing was wrong.
Old Feb 13, 2013 | 07:04 PM
Craftysince86's Avatar
W211
head gasket
Old Feb 13, 2013 | 08:45 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
Had this problem with my 2007 E550 for a while about 40k mikes ago. Stopped on its own and hasn't happened since. I figured maybe carbon build up.
Old Feb 14, 2013 | 01:44 AM
AMGAffalterbach's Avatar
2014 BMW M235i
Should be carbon build up if it goes away but it doesn't and it's a gray or bluish smoke then it could be that the piston rings may be worn, valve seals may be worn, or damaged or worn valve guides. Makes sense to me that they would say nothing is wrong due to the fact that they can't really inspect these parts with ease and would probably charge you and arm and a leg for that labor. Could be the head gasket - that's generally a whiter colored smoke.
Old Feb 14, 2013 | 09:41 AM
WildWolf's Avatar
2019 E63s
Thx for the replies. I notice the smoke as I am entering the highway. I like to "goose it" from 1st gear all the way up to the "legal limit". above 5,000 rpm while under load, I notice the smoke in the rear view mirror. If I let off the throttle and the rpms are above 5,000, no smoke.
Old Feb 15, 2013 | 01:00 AM
2014 BMW M235i
I think it might be some type of failing seal then to have it smoke above 5000 and under acceleration.
