What is this and how bad is it? [Pictures]
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
I was trying to inspect my front flex disc but there is something in front of it that is clearly cracked.
Anyone know what this would be?
How critical is this? Should I stop the car until I get it fixed?
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
I think that this is your flex disk one side is attached to the trany or differential and other to the drive shaft (disk is between drive shaft and either part).
Good, I was thinking the flex was just the one behind and it would be two separate parts. Thanks!
Second look
Are you sure they are not two individual parts?
Trying to buy the replacement the pictures show a single disc
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
96 and 08 911 turbos
The flex disk is sandwiched between the driveshaft and the differential or transmission.
The bolts, however, do not go through from the driveshaft to the diff/tranny. The driveshaft bolts to the flex disk, and then, with separate bolts, the disk bolts to the diff/tranny.
No no.
If I order a new flex disc I will only get the second disc that is behind?
No, it is not part of the driveshaft; it only has different way of attaching to it and to the transmission. You can order the front one or both. They do have same part number A 215 410 00 15.
Thnx to all!
There was actually one part number for rear and a different for front in the EPC for my VIN. Also ordered the rubber boot bearing though I'm not sure how I will change it.
Hope this cures a whining/grinding/growling sound when I brake with the engine...
Parts:
A 211 410 01 81 RUBBER BOOT BEARING
A 211 410 04 15 FLEXIBLE JOINT DISC (PARTS KIT), REAR
A 211 410 02 15 FLEXIBLE JOINT DISC (PARTS KIT), FRONT
Parts:
03 E500 and Corvette
It would have been great if designed as a unbolt and bolt in item. I worked on industrial equipment for 35 years and we used similar couplings but we made them quick change. Keep it simple. This would be a great opportunity for MB to reapply the KISS on a common change item.
My new flex discs arrived and they are just the part behind what I am now thinking is a vibration damper as pictured above.
I can't find the damper in EPC, all I found was threads on W201 saying it is better to just remove the hole damper as it may separate and cause damage while contributing nothing to ride quality.
Any thoughts?
Any thoughts?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
If you found the flex disc, just go back to that picture and all will be clear.
Based on you first post the damper is cracked and badly damaged, the flex disc look fine!!
Yes it looks that way, I'm leaning towards just removing the damper. There is nothing about it in EPC and I haven't found anyone with a w211 mention it. I'm just concerned on what damaged it in the first place and if I'm now going to have more vibrations.The other alternative I have now is just leaving it in but I read on other chassis forums that will result in serious damage if separation occurs.
The vibration damper is included in number 90, the kit and you can't just buy the damper, therefore you need 211 410 02 15 and 211 410 04 15.
If you have not done this before make sure you read VERY CAREFULLY MB AR4110P0050T the removal and install of propeller shaft, there are some little tricks that if not followed--------you will be back------- how come bla bla
Thanks for the advice, I definitely don't want to come back here and increase my rep as a noob.
