E-Class (W211) 2003-2009
Command Screen is blank after "Engineering mode"
Old Mar 7, 2013 | 09:31 AM
AllHailBenz's Avatar
2008 E350 4MATIC
So this morning I turn on my car and the command screen flashes a "triangular exclamation mark" and then the screen goes blank... The day before I replaced the iPod interface cable (pretty simple) and also entered "Engineering mode" by pressing 3-5-7... Change it so that the screen would boot up and display "AMG". I really need some suggestions and solutions.
P.S: It's a 2008 E350 Sport 4MATIC
Old Mar 7, 2013 | 09:48 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Just a guess...it's to do with the iPod interface. Are you sure it's the correct part number to install?
Old Mar 7, 2013 | 10:14 AM
2008 E350 4MATIC
Yea Boardboy330... When I replaced the cable everything worked perfectly... It this morning... Not so perfect. It's stuck in SAT radio being that's where I left off when I turned off the car for the night... I can switch through stations from the steering wheel only now.
Old Mar 7, 2013 | 10:43 AM
Have you attempted to get back into it and see if maybe it was stuck in ENG mode. Maybe you can switch it back. Again - just guessing as I have not dealt with this before.
Old Mar 7, 2013 | 10:57 AM
2008 E350 4MATIC
I definitely tried to get back into ENG Mode by repeating the 3-5-7 method.... Still nothing. I can tell the screen is on b/c everytime I go under an overpass I can see the black screen lit.
Old Jan 8, 2014 | 09:28 PM
dreadinny's Avatar
2008 E350
I have the same issue. Any solution?
Old Jan 9, 2014 | 12:41 PM
2008 E350 4MATIC
Sorry dreadinny.... I took it to a friend that work for mb of Manhattan and he tried running Star Diag. Nothing worked. I ended up shelling out $1000 for a refurbished one at MB of White Plains.
Old Jan 9, 2014 | 03:32 PM
starbrite's Avatar
2004 E320
Wow, that turned out to be one expensive iPod connection.
You just never now with these cars. I disconnected my main battery for about an hour and when I reconnected it, I lost all my keyless go functions.
Old Jan 10, 2014 | 01:18 AM
dreadinny's Avatar
2008 E350
Ouch!
