E-Class (W211) 2003-2009
HID Conversion
Old Mar 15, 2013 | 02:28 PM
desired_speeds's Avatar
2007 SL55 AMG
Originally Posted by AMGAffalterbach
Alright understood and clarified, thanks a million.
By the way - off topic - but your E55 O_o wow. Love seeing your signature never knew I'd like that color so much especially with black wheels.
Thanks! I liked those wheels a lot when I had them, but I wanted something wider. I may consider picking up another set in the future. The wheels looked even better in person because you could see the blueish flakes in the gunmetal powdercoating under direct sunlight. I'm still not too fond of the car's color, but it's definitely grown on me a bit.
Old Mar 15, 2013 | 06:00 PM
Tschuss_Bill's Avatar
2005 E320 CDI
Originally Posted by desired_speeds
Between my friends and I, we have gone through many sets of HID in the past few years. Morimoto was the only kit that stuck out to me. I swear their 35w shines like most 55w kits on the market. They also offer the 50w ones which I'm assuming are even brighter. (I haven't tested their 50w yet)
+1 Morimoto 35W (with Philips 85122+)
Retrofitsource guys talked me out of the 55W. Less reliability over 35W format. Philips bulbs will outlast the other stuff.
For those that want to spend as little as possible, Morimoto and Philips are not the best option.
Old Nov 2, 2013 | 03:11 PM
topracer's Avatar
2006 E350 4matic
Angry
I need help with the Morimoto 3Five (35w) H7 low beam kit on a 2006 E350 with halogen lights.
First, the kit that I received was missing a connector. TRS sent me the new part. (Good customer support)
Second, when I tried to install the kit using the Can-Bus harness, the light flicker for the first second and stayed off. 50% time the light would stay on, very inconsistent.
The reason I bought the Morimoto kit with Can-Bus harness, because I believe I don't need to program HID present on the car. Am I wrong?
Could it be the polarity from the original car H7 bulb connector? I think yellow is "+" and brown is "-". So, I connected the red wire on the Morimoto kit to yellow and black wire to brown.
I am planning to return the kit.
Old Nov 2, 2013 | 04:29 PM
topracer's Avatar
2006 E350 4matic
I did the battery test. I could have a bad ballast. Having bad luck with TRS. I connected the ballast with bulb, no can-bus harness, directly to the battery. One ballast is inconsistent, on/off. The other one turns on every time.
Old Nov 3, 2013 | 07:17 PM
AMGAffalterbach's Avatar
2014 BMW M235i
One of my lights on my DDM kit is no longer working on the passengers side, doesn't even try to spark. I'm fairly certain it's the ballast so I will have to RMA that part. A little disappointed but at least it's been worth it.
Old Nov 6, 2013 | 10:09 AM
2005 E320 CDI
Relax, TRS will replace if defective.
Old Nov 7, 2013 | 10:35 PM
  #32
topracer's Avatar
2006 E350 4matic
TRS service is great. They are sending me a new ballast. Instead of a plug-and-play kit, I think I have a plug-and-replace kit. ;-) Hope everything will work this time.
Old Nov 19, 2013 | 10:17 AM
  #33
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
Which one did you get? 35w or 55w and color?
I have 35w HID DDM fog light with 6k color and i really like it.
Just wonder if i go with 55w on low beam, would 6k be the same color as my fog light.
Thanks,
Old Nov 22, 2013 | 01:09 PM
  #34
2014 BMW M235i
Hopefully you found my list on the other thread looks like you did. I have 55w low beams 6000k, 35 watt fogs 5000k, 5000k city lights and 5000k Phillips Diamondvision high beams (non-HID). They match fairly well but 6000k for both would probably be good.
Old Nov 22, 2013 | 01:55 PM
  #35
btv94's Avatar
Yes i did find your post and ordered 55W low beam along with 6000K color.
Thanks,
Old Nov 25, 2013 | 01:20 AM
  #36
2014 BMW M235i
I think you'll really like that color and setup let me know how it goes!
Old Dec 9, 2013 | 01:22 PM
  #37
btv94's Avatar
For me, 6000k is not that blue and I’m glade that I went with this color. Never drive in snow so I won’t know what it would be like. Thinking about order the spare/second set since 55W DDM coming from china and took 3 weeks for delivery.
Old Dec 10, 2013 | 02:32 AM
  #38
2014 BMW M235i
Finally drove in snow for an extended period of time with HIDs and they were amazing, and yeah I would definitely get another ballast and set of bulbs as backup because mine took 2 weeks to ship originally from China (I kind of hate the fact they're now basically cheap eBay ballasts) and one went out within a matter of weeks. They won't just send you another one, you have to RMA it going through a 50 page process. DDM Tuning won't even take your word for it they test every ballast you send back so you might be out for over a month... easier just to order new ones since their customer service sucks, frankly
Old Dec 10, 2013 | 10:02 AM
  #39
btv94's Avatar
WOW!!!
Over a month? I really need to get a spare/second set since their price is not that expensive compare to other.
Old Dec 10, 2013 | 11:19 PM
  #40
2014 BMW M235i
That's what I'm guessing! Because you would have to send it to them, they would have to test the ballast (I assume this would take a week or two) plus another two or three weeks added for shipping of the new ballast if they determine the ballast needs replacement... kind of ridiculous but whatever. Learned my lesson lol
Old Dec 11, 2013 | 10:50 AM
  #41
btv94's Avatar
Prior DDM HID installation, the right side headlight was out for three weeks and I don't want to go through that again.
I just ordered second set without error eliminator for my spare. Hopefully i don't have to use them.
