E-Class (W211) 2003-2009
New to MB-navigation question
Old Mar 25, 2013 | 10:12 PM
jgregory8's Avatar
2004 E500 RWD
Hi I'm new to MB, just purchased a 2004 E500 RWD and I have a question on how can you tell whether navigation/phone is installed or prewired. When you press navigation button it say navigation device is unavailable and when you press phone it says phone not installed. Haven't taken any pictures yet. I will be pretty disappointed if navigation not installed.
Old Mar 26, 2013 | 02:07 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Check your trunk, DVD reading unit if you have it should be on the left hand side under the rear fender lining.
Old Mar 26, 2013 | 05:35 PM
e50zero's Avatar
E500
+1
also for phone you should have a unit in the center armrest prewired.
Old Mar 26, 2013 | 08:21 PM
isstay's Avatar
According to the message he gets, he does not have phone installed, but for Navi there is something wrong w/the drive or is missing.
Old Mar 26, 2013 | 09:49 PM
jgregory8's Avatar
2004 E500 RWD
My vin is: WDBUF70JX4A537801, and I will check the center console for cradle and the left side of the trunk for the nav drive.
Thanks again
Old Mar 26, 2013 | 10:10 PM
isstay's Avatar
Well according to the data card for your car you do not have Navi installed.
Old Mar 27, 2013 | 09:10 AM
jgregory8's Avatar
2004 E500 RWD
Navigation
If I purchase a navigation DVD drive, can I have it installed and how much would the price be. Also did you noticed when you viewed my data card on the phone installation?
Old Mar 27, 2013 | 10:37 AM
isstay's Avatar
It says that you have Command DVD Plus (w/o Navigation) - SA Code 528. You probably will be able to install DVD reader in the trunk and connect it to the head unit (usually those cars are prewired and you just plug the addition) but you probably will need to change Command settings through SDS to activate it.
Phone code is 384 - Telephone Preinstallation CP High for USA. I am not sure, but most likely it is same situation - prewired but not installed if you do not have it in the center console under the arm rest, or the unit is missing.
Old Mar 30, 2013 | 11:23 PM
jgregory8's Avatar
2004 E500 RWD
Which navigation DVD drive
Which one of these drives will work/compatible with 2004 E500
Nav A 200 820 60 85
Nav A 220 870 35 89
Old Mar 31, 2013 | 08:07 PM
jgregory8's Avatar
2004 E500 RWD
Which navigation DVD drive!
Old Apr 1, 2013 | 10:20 AM
jgregory8's Avatar
2004 E500 RWD
Which DVD-navigation Drive
Plutoe,
This is not software that I'm trying to purchase. According to previous post, my vehicle is pre-wired for Navigation, just doesn't have the DVD drive or reader installed in the trunk. These number what I gave you were for the naviagation drives or readers to install in the trunk to connect to the head unit of the command console. So which one of these would be compatible?
Nav A 200 820 60 85
Nav A 220 870 35 89
Old Apr 1, 2013 | 10:33 AM
jgregory8's Avatar
2004 E500 RWD
According to previous posts, my vehicle is pre-wired for Navigation, just doesn't have the DVD drive or reader installed in the trunk. These number what I gave you were for the naviagation drives or readers to install in the trunk to connect to the head unit of the command console. So which one of these would be compatible?
Nav A 200 820 60 85
Nav A 220 870 35 89
Old Apr 1, 2013 | 11:22 AM
konigstiger's Avatar
'71 Pinto
2208703589
Old Apr 1, 2013 | 02:17 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
it would be most likely cheaper for you to just ditch the factory setup and go aftermarket. the oem nav is dated. there is a pnp adaptor called opti1 making aftermarket,installations simple.
Old Apr 1, 2013 | 10:03 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
The nav isn't overly good. Pretty cumbersome compared to what you can buy for $150 and stick on the glass when needed.
Old Apr 1, 2013 | 10:25 PM
jgregory8's Avatar
2004 E500 RWD
Navigation drive
Thanks everyone for all your help and assistance
