E-Class (W211) 2003-2009
Dynamic seat troubleshooting....
Old Apr 15, 2013 | 02:30 PM
DaveW_396's Avatar
2014 E550, 2017 E300
I have seen a couple posts for troubleshooting dynamic seats. Most are manual methods.
If one has the STAR software is there a way to perform diagnostics on the dynamic seats?
My Dynamic seat lights and controls blink and make clicking sounds when I push them, but nothing happens. This sounds similar to
https://mbworld.org/forums/w211-amg/...t-working.html
Just wondering if one has the STAR software if this would simplify the investigation? If so where would one navigate to in the SW to do this?
DaveW
Old Apr 15, 2013 | 02:35 PM
AMGAffalterbach's Avatar
2014 BMW M235i
PM Plutoe he is a DAS Xentry lover who could tell you where it would be. Or wait for him to respond.
Welcome to the forums by the way! Thanks for doing your research ahead of time before posting also it will get you very far here.
Old Apr 15, 2013 | 02:59 PM
efiftyfizzle's Avatar
W212 E63 AMG S Model
DaveW
Is it both of your seats? Mine is doing the same thing... I can hear the pump come on but nothing is happening and then I believe it shuts off after a couple minutes.
Old Apr 15, 2013 | 03:13 PM
DaveW_396's Avatar
AMGAffalterbach - Thx. Will do.
efiftyfizzle - yes both seats behave the same. light will come on, solenoid / valve clicks, but nothing happens.
Via the STAR software I have a code stored stating that pressure cannot be built up possible leak. I am just wondering if the STAR software has a diag routine to help investigate these troubles (i.e. trying to fill each bladder one at a time on each seat to help detect where the leak is). I assume I have a major leak if it cannot even build pressure in the resiviour, but once I fix that I wondering what I can do to see if that was the only problem.
Regards,
DaveW
Old Apr 17, 2013 | 05:14 PM
Something may have melted and is causing the pump to shut off... you probably need to take the housing apart in the left side of the trunk to get to it and check it out.
