Dynamic seats not working!
Old Jul 23, 2011 | 02:54 AM
tbal's Avatar
Haters crazy
Angry Dynamic seats not working!
Read a few threads, still have a few questions... I almost never use my dynamic seats lol, today decided to use them, and to my surprise they don't work! When I press the "pulse" button, it just steadily flashes, than turns off. No codes thrown, SRS or anything like that...
Anyone know which fuse/relay is for the dynamic seats?
Is their a reset procedure for the dynamic seats?
Possible solutions I read are:
New dynamic pump
Dynamic seat module
dynamic seat control switch
How can I be sure if the pump is dead? Can the option some how get disabled say after unplugging the battery, and needs to be reactivated via star?
Cheers guys any help would be great! Not really disappointed its not working, because I didn't really use it, but now that I know it doesn't work, its going to annoy me lol.
Old Jul 23, 2011 | 03:34 AM
tbal's Avatar
Haters crazy
Here's a video of where the pump is. Seems to be working? What's that loose hose? Sounds like air leaking somewhere.
http://www.youtube.com/watch?v=wWCTr...e_gdata_player
Old Jul 23, 2011 | 10:23 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
sounds like the pump is indeed working (loud ******* after you remove the foam lol)
I would suspect that you would have a leak.
As an FYI, if you replace the pump you need star to re-activate it. I did mine and was lucky to have a star with me. My light would blink as well etc.
Do both seats have the same problem? Could help isolate a leak if there is one.
Old Jul 23, 2011 | 01:08 PM
tbal's Avatar
Haters crazy
Lol the **** is hellla loud!
Both seats are doing the same thing. What about that loose hose that doesn't seem right...
Old Jul 23, 2011 | 03:32 PM
tbal's Avatar
Haters crazy
So found a blown fuse in the trunk. 4th one from the bottom, replaced it with the 7.5a that was previously there. Thinking this is NOT the dynamic seat fuse, because I read somewhere that fuse is 40amp. Whats the the correct fuse size/location for the dynamic seat?
Old Jul 23, 2011 | 04:02 PM
tbal's Avatar
Haters crazy
http://www.mercedestechstore.com/pdf...2011-29-02.pdf
Page 14, suggests 2nd from bottom? That cant be right... I have a 40amp fuse at the bottom, dont see a "reserve" location
Old Jul 24, 2011 | 12:46 AM
tbal's Avatar
Haters crazy
anyone
Old Jul 25, 2011 | 04:03 AM
tbal's Avatar
Haters crazy
Shardul? lol
Old Aug 5, 2011 | 03:51 PM
dshuddy's Avatar
E55
Same Problem
I seem to be having the same problem you've described. I don't see the resolution in your thread. Were you able to resolve it?
Old Aug 5, 2011 | 03:54 PM
daniel3ooo's Avatar
2010 Prius :)
I too have the same problem except:
My pulse seats work and the dynamic seats work only the slightest when I press the button but soon dies or turns off..I haven't looked at it yet since I don't really use the dynamic seats but would like to find a solution!
Old Aug 5, 2011 | 04:07 PM
tbal's Avatar
Haters crazy
All the pumps etc seem to be working for me. Because I disconnected the battery overnight awhile back, I think the system got deactivated. Needs to be activated via star...
Old Aug 5, 2011 | 04:36 PM
GregMB's Avatar
tbal,
There should be a menu option available in the cluster to turn them on... I know I've seen it there. There's even a setting for "Soft" or "Aggressive" dynamics (or something like that)...
Does the light not even come on when you press the seat button directly?
I had my DS seat shut off inexplicably once on a long trip and wouldn't come back on with the button at all. The next day it was back to normal like nothing had ever happened.
Old Sep 11, 2011 | 02:29 PM
tbal's Avatar
Haters crazy
Originally Posted by GregMB
tbal,
The only thing I see in the menu is to turn the dynamic seats soft/aggressive... off? hmm maybe i will double check, but dont remember seeing anything...
When I press the button on the seat, the red light blinks continuesly...
Old Sep 11, 2011 | 02:39 PM
GregMB's Avatar
The blinking light isn't normal.... Maybe it's flashing an error code pattern?
My seat shut off again on a long trip, but went back to normal after a stop where I shut the ignition off completely. Not sure why it's happening but I don't care enough (yet) to have it diagnosed.
-G
Old Sep 11, 2011 | 02:41 PM
tbal's Avatar
Haters crazy
I checked the pump its working, the seat pulse and dynamic are the only things not working, maybe it needs to be activated via star? It seems like this happened since I unplugged the battery, but seems like no one has had this problem before lol
Old Sep 11, 2011 | 04:13 PM
Legal-z's Avatar
'06 E55, '86 951,
not that it helps, but i have the exact same problem, blinking light and all, in my '06 e55. just started working on it. please update if you find anything. i'm starting the checklist of things to look at now.
Old Sep 11, 2011 | 04:17 PM
Legal-z's Avatar
'06 E55, '86 951,
in doing some research on this, there is mention in one thread that there is a tube/hose that carries air that routinely gets crushed or melts and blocks the flow of air. not i just have to find and trace that tube and i'll update you if that's the problem.
Old Sep 11, 2011 | 04:52 PM
tbal's Avatar
Haters crazy
Sweet keep me posted!
Old Sep 12, 2011 | 02:05 AM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
I'm having the same issue with both seats. The dynamic light will stay on, but the pulse lights just blink and go off. I think the pump is either bad or there's a leak somewhere. Does anyone know the troubleshooting steps for these over-engineered seats? What must be done in the STAR diagnostics to test/reset the pump? Very frustrating...
Old Sep 12, 2011 | 08:56 AM
dshuddy's Avatar
E55
Dynamic Seats Not Working
I was experiencing the exact same lights flashing on the Pulse button and I had been hearing a high pitched sound from the trunk, etc. Took it to the dealer, they diagnosed the problem as a bad pump. It has now been replaced and all is back to normal. Luckily everything was covered under warranty.
Old Sep 12, 2011 | 02:15 PM
tbal's Avatar
Haters crazy
Wow seems like it's a common problem with these pos seats
Old Sep 13, 2011 | 05:32 PM
Martin6683's Avatar
2005 E55 AMG, 2000 Viper GTS (head,cam, supercharged), 2014 Mazda 3 (daily), 2004 F150, Harley& Busa
tbal,
i got the exact same problem!!! I havent tried looking into the issue yet either.
Old Sep 13, 2011 | 05:35 PM
xpl0sive's Avatar
CLS55 AMG
if you need to use STAR, you're welcome to use mine
Old Sep 13, 2011 | 06:25 PM
tbal's Avatar
Haters crazy
Thanks bro! I'll give it ago and see if there is anything in there for the dynamic seats...
Old Sep 13, 2011 | 06:26 PM
boost420's Avatar
S55K AMG
I just had mine diagnosed at the mechanic. Turned out my check valve failed causing the pump to continue running and eventually melting the hose. The motor can still be turned on but the pump is completely ruined. I bought a replacment used unit with a 1 year warranty for $247 otherwise, on the W220 it is an $800 part.
