Ho do you remove Front Sway Bar?
I have found out that you can not purchase new sway bar bushings that mount the bar to the frame. I have removed both brackets that clamp the sway bar to the front frame of the car. I have the new sway bar in route with two new bushings installed. But I need help figuring out how to remove the sway bar from the vehicle as it looks as there is some major interference.
If anyone has pictures or a good explanation I need it so bad. Please help. Thanks in advanced.
Jeff
Jeff
