Low Idle
I have a low Idle (500rpms) and a slight vibration. I know the Vibration is from motor mounts, it has 103k miles on it. My concern is the low RPM. I just had the Service D and new Spark Plugs done. little over 1500 miles ago.
My idle doesn't jump. While in park it is at about 750rpm, in neutral it will sit at 800rpm and when in drive it will settle to 500-600rpm (I can't get the exact number, but it doesn't jump up or down). Is that normal?
Each mount is about $140, make sure they replace the exhaust bolts if you ever want to remove them again.
