E-Class (W211) 2003-2009
Bulb upgrades?
Old Aug 30, 2003 | 06:47 AM
OGBenzo's Avatar
E500
Bulb upgrades?
Has anyone upgraded their stock bulbs yet? I usually upgrade all the bulbs on all my past benzos, and I tried doing that to my E500 today.
1. Its a huge pain in the *** taking apart almost the entire trunk to get to the rear lights. You need to pull out the bottom frame in order to get to the rear assemblies. Then it turns out all the lights are mounted on what looks like a chip board made of plastic with metal all around it. All the bulbs are irreplaceable, I wanted to change the reverse and signal bulbs to superwhite and the store said they have never seen those bulbs before. So I guess if one blows out, Id have to buy it from the dealer.
2. Front. Ive upgrade my stock HID bulbs to Stage III 8000k bi-xenon bulbs. Ive got some in the classifieds if anyone is interested. The look GREAT. Way brighter than stock, and a blueish violet hue to it, I guess because of the projector.
3. I changed the 2 yellow turn signal bulbs to Hyper white and it looks 100% better. Because of the reflector built into the housing and using 2 bulbs for the turn signals, the light is much more noticeable.
4. Inside round driving light. This is your standard wedge bulb. I tried installing LED super white bulbs, but it wouldnt work, I guess the car doesnt recognize it as a real bulb so no power goes to it. So I put in hyper white wedge bulbs. Again it looks GREAT. Not as yellowish as the stock ones, but not so bright that it takes away from your HIDs. Subtle hue o blueish white light.
5. Fog lights. Here I ran into another problem. The bulbs are H11s and the store has never seen or heard of them. So I guess you either go without or have to buy replacements from the dealer. Unless someone here knows where I can find some They look very similar to 9005/9006 bulbs but smaller.
Ill take some pics over the weekend if anyone wants to see them, or would like a source for replacement bulbs, please contact me at OGBenzoCA@aol.com.
Old Aug 30, 2003 | 11:18 AM
silverEEE's Avatar
2003 Pewter Silver E500, 18" Style IV w/Pilot Sport
Here's a good thread that details the replacement lights........
https://mbworld.org/forums/showthrea...highlight=piaa
or just do a search on "PIAA".....
Old Aug 31, 2003 | 08:45 PM
michakaveli's Avatar
E300
Re: Bulb upgrades?
Pix please...
Old Aug 31, 2003 | 09:04 PM
Rave E55's Avatar
You can paint any yellow signal bulb yellow, this will give you a clear look and will still signal yellow when activated, great look and cops won't harass you for non yellow signals. A high heat silver spray paint works best.
Old Aug 31, 2003 | 10:03 PM
E300
And it doesn't block th elight output? I've tried a high heat before and it ended up blocking the output...
Old Aug 31, 2003 | 10:16 PM
Rave E55's Avatar
I didn't notice much, a quick light blast of paint did the trick, don't over paint the bulb.
Old Aug 31, 2003 | 11:52 PM
etenn's Avatar
E-500
There have been a couple of very long threads lising all the bulbs for the W211.
Try this link:
https://mbworld.org/forums/showthrea...ht=light+bulbs
