E-Class (W211) 2003-2009
Who has over 100,000 miles on their gasoline W211?
Old 12-03-2017, 09:25 PM
  #226
Shack1's Avatar
06 E350
Originally Posted by 62bassman
06 350 4M with 105K and no major issues to date. Just replaced both batteries, flushed radiator, tranny and transfer case, new tires and rear brakes, all elective preventative so I can keep the car for another few years. Still get 24-27 mpg on highway, and the best car I've ever owned. Also, have a great relationship with my dealer service manager and that makes a big difference to my ability to understand what to expect in the future. I've budgeted 10 K for scheduled maintenance and repairs for the next 100K miles. Try buying a new car for that.
The balance shaft problems some are so worried about are no different than any other internal wear concerns and much dependent on proper lubrication intervals and staying with the
Mercedes prescribed service program. It's amazing how much money some people spend on having a new car every 3 years.
Sorry but your gibberish about the balance shaft is BULLSH$T. My 06 E350 had the issue at 44700 miles, oil changed at least at 10k miles with Mobile1 0-40 and fleece filter.
I was a year out of the Tired LAWSUIT settlement but MBUSA did cover 15% of the $6400 repair.
Old 12-04-2017, 10:32 AM
  #227
62bassman's Avatar
18 GLC300 4M
Your post indicates rage so my regrets for provoking you, but thanks for first apologizing.
It would be useful for others following this to know more details, such as whether you are the original owner and any notable circumstances that preceded the failure. Realizing early on that my car is within the affected range, I’ve done a lot of research on this topic and have studied correspondence from the claimants as well as the legal filings and court documents. Also have gotten into the weeds with three different service reps and two certified MB technicians who are very familiar with the balance shaft premature wear who all agree that the gear was prone to failure but rare to happen when scheduled lubrication intervals are followed.
I like the car and, although financially able to deal with the costs of trading it for a new , or newer model, I just don’t care for the way MB has succumbed to the latest exterior and interior design trends. Why does one of the best engineered automobiles in the world now look like it was designed by the same teams that seem to make every other import look pretty much the same? Again, sorry for your bad experience and good for you to deal with the failure while keeping the car. Mine is now at 132K and getting an A service that is costing about half price with the MB winter service discount promotion. I handle all basic maintenance items myself or with a trusted indie but like to have the car inspected yearly at a competent dealer.
Old 12-05-2017, 02:34 AM
  #228
Shack1's Avatar
06 E350
Ok I am the second owner, bought it with 22k in 2009, three years old! Took it to dealer for B service and a belt pulley recall. Since then I have changed the oil four times at 10k intervals with 0-40 M1. The car had 44700 when the check engine light came on.
If you have STUDIED this issue you would know they were sued twice and the settled the second one with a tiered reimbursement to replace the DEFECTIVE balance shaft.
Even if I had only changed the oil every 20k this part should not have failed so soon. I am lucky MBUSA covered 15% but imo they should have covered it ALL!
I get very upset when someone states that lack of maintenance in the reason for a documented inferior made part, albeit NOT a part made by Mercedes, its still their responsibility.
Don't even get me started on the SBC unit, I guess at some point that is going to rear its ugly head.
nguyenphananh (12-05-2017)
Old 12-05-2017, 11:45 AM
  #229
kjb55's Avatar
2025 AMG E 53 (on order); 2018 GLC300 4Matic; 2003 360 Modena
It is what it is. Pick a manufacturer, any manufacturer, and there are models and model years to stay away from. You got burned on a low mileage failure - not sure if you should be so angry at someone who hasn't experienced the problem at much higher mileage and isn't caught up in the hype. I change my oil every 5k miles - and the dealer was convinced I never would have experienced the problem. It still didn't sit well with me - so I changed it. The W211 is a great car - period. The balance shaft gear is an unfortunate instance in a very successful model run, and far from a high percentage failure rate. The SBC technology is exceptional for it's time. By 2006 it's very robust and extremely reliable - with replacement items way down in price and enough information to service it.
It can always be worse with bad rod bearings in Lexus and BMW models, IMS bearings in Porsches, valve guides in Ferraris, crappy trans in Honda / Acura models, head gasket issues galore in Toyota's. Just think how boring the forums would be without all this fun to be had fixing the OEM problems!
Old 12-05-2017, 12:17 PM
  #230
Shack1's Avatar
06 E350
Were you the one who replaced the shaft himself?
Old 12-05-2017, 10:29 PM
  #231
kjb55's Avatar
Yes.
Old 12-05-2017, 11:41 PM
  #232
Shack1's Avatar
06 E350
Yes.
Thanks for pointing out those other car's issues, forgot about Toyota head gasket debacle.
Glad I spent the money on my car, im sure engine wise I should have at least 50k without a mechanical issue, but Im worried about the SBC system.
The car is now 11 years old even though I only have 45k miles.
I have not had the brake fluid changed once. I should probably have my local euro indy shop do that.
My car is in a desert location and always garaged.
Old 12-28-2017, 06:44 PM
  #233
techartgt3's Avatar
W211 e63
W211
I had a 2003 e500 I sold with around 210k miles. It need both of the rear air struts replaced which is why I sold it. Only thing I did to it was replace the rear control arms and tires.
I since bought a w211 e63 with 94k miles that now has 101k miles. At 75k the previous owner replaced:
- all 4 air struts
- motor mounts
- a/c compressor
- power steering pump
- water pump
And he had all of that done at a MB dealership so he dished out a pretty penny. All I had to do to it so far was an oil change and some tires 😎. It should be good to go for another 100k.
Old 01-03-2018, 05:59 PM
  #234
adabuf's Avatar
2003 E320 Estate Avante Garde
Red face Adabuf
146000 miles at 14 years 2003-2004 wagon. SBC has just raised it's ugly head.
Old 01-03-2018, 07:41 PM
  #235
Heatwave's Avatar
2007 E350; 2018 GLE350
134,000 miles on wife's '07 E350 Sport (non-SBC). I replaced the manifold earlier this year. Otherwise ... no repairs other than usual maintenance items.
Old 01-04-2018, 09:54 AM
  #236
NCTRNL's Avatar
2005 E500 Wagon
147,500 on a 2005 e500 Wagon. I've had it about a year, changed the front struts and axles, crankshaft position sensor, transmission filter/pilot bushing, a few oil changes, transmission fluid, sprayed the bushings on the swaybar with silicone spray because of all the cold weather squeaking. I'll be honest, I regret buying this car but now I'm stuck with it. I'm waiting for the rear bags to go out, going to buy remanned OEM axles because the FEQ ones I put in are terrible, and always wondering about the SBC.
Old 01-04-2018, 11:31 AM
  #237
Gersh320's Avatar
E320 & X166
211,211 miles 2003 E320. Running like a CHAMP
Carcheologist (01-18-2018)
Old 01-04-2018, 05:16 PM
  #238
TSENIOR's Avatar
03 mercedes e500 5.0 v8 04 honda accord 3.0 v6
230k miles. Original trans and engine. Still runs and shifts perfect.
Old 01-06-2018, 10:35 AM
  #239
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 OM642 ; R107 M117, Sierra 1500 LZ0
122k on an 07 Bluetec. Original engine and transmission. Oil cooler seal replaced proactively. Original DPF as well.
Old 01-16-2018, 12:58 AM
  #240
Jin Ho's Avatar
2014 MBenz E350 4matic
2007 E550 4matic, just hit 101K, runs fine now
Motor Mount
Transmission Mount
Electrical fan (front part of car)
Oil changes
Brakes & rotors
Recall fuel tank replacement
Front air pump module
No problems yet but received the Service D sign...TBC
Old 01-18-2018, 12:45 AM
  #241
Carcheologist's Avatar
2010 ML350 Bluetec, Alfa Romeo GTV6
2005 e320 wagon, 2WD
189k miles
4th owner
the 3rd owner didn’t do much if any repairs so we got it cheap knowing it needed some work.
Since we bought it 2 years ago I have replaced:
Voltage regulator (2x, first cheap one died in 6 months, OEM Bosch going strong)
Motor mounts
Spark plugs, air filter, cabin filter (maintenance)
Front control arms and ball joints
Water pump, upper radiator hose, serpentine belt
Fuel pump (MB issued a warranty extension a few months later, argh)
SBC Pump ($1800, ouch)
2 new Arnott rear airbags (easy job)
New tires
Passenger seat control switch (used)
Driver sunvisor (used)
Console levers
I did everything myself except the SBC motor. That was a fun surprise, but my wife and I both love the car, it runs great, is fun to drive and is super comfy on the freeway. It has a great sound system and when we need more space we throw a box on top. With snow tires I don’t need awd to go skiing.
We have spent a lot on it but still love it and plan to keep it for years.
Old 02-05-2018, 02:31 AM
  #242
PJE
PJE's Avatar
2008 E350 4matic sport
Very happy with my E350
I have a 2008 E350 4matic. champaigne, sport package, loaded with options, P2 pkge, Nav, sunroof, fold down rear seats for trunk access, with 210k miles. Bought it with 21k miles on it. Very few problems. Redone brakes 4 times, last time new rotors and new front calipers. Keyless Go/Entry driver's side doors work with FOB, not handle buttons. Replaced idler pulley, and front dampener, and have done most work myself after warranty. Dampener was the toughest job only due to the torque required and the special tools. Had windshield replaced once, and it is due again. I love this car it. For about 6 years I drove it over the Cascades Snoqualmie pass every day, a 100 mile round trip as daily commute with lots os winter snow and ice. Never a problem with it no matter how bad the conditions, and with Blizzack WS80's on all 4 wheels it is a virtual snow cat..... Just replaced both windshield washer nozzels, and one headlight washer nozzle, and will replace thermostat tomorrow. I also put a trailer hitch on it and haul our 5x10 aluminum utility trailer with it, which gets some interesting looks and comments.
ET2000 (05-24-2024)
Old 02-06-2018, 12:39 AM
  #243
rodneypierce's Avatar
2009 e550 4Matic
Just crossed over 111k miles on my 09 e550 4matic. I've done all front end components minus struts and lower control arms. Transmission service, transfer case service, front and rear diff service. Thermostat, keyless entry door handles on the driver side (front and rear, rear is out again) heater control valve, idler pulley, brakes all the way around (rotors and pads) airmatic pump and just did the rear bags this past weekend.
Overall I absolutely love this car.
Old 02-07-2018, 11:03 AM
  #244
furukawa63's Avatar
2007 e 63 amg
2007 e63 amg
250000miles
2 radiator
4 front air suspension
air pump
3 camshaft
rotors and brakes
etc etc
Old 02-07-2018, 12:32 PM
  #245
cbpldc's Avatar
W211 E550
I've got a 2007 E550 4Matic with 145k miles on it. The front differential failed and broke a front axle while we were out of town over the new year. Oh yeah, and on the way out of town, a coil failed, which isn't really a big deal, but I knew that I'd be replacing all of them soon. I got this car form the original owner with over 30 pages of service records from the dealer.
I love driving it, but I've only owned it a couple of months now and its kind of been a pain. Hopefully I've got all the issues lined out and it will be reliable for me.
Chris
Old 04-24-2018, 04:53 AM
  #246
JordanA's Avatar
2004 E320 Wagon, Base
First post! I've got a 2004 E320 Wagon (yeah, I know I'm in the sedan forum). It has been in the family (2nd owners) since 2006, when it had 36K miles on it. It is currently operating on the original engine and transmission at 346K miles. Yes, 346K miles (used to drive from North Carolina to Florida at least once a month since 2006). I haven't been through the file (it's a big file...) that came with it of service records to confirm, but apparently the engine and transmission (except for fluid changes) have never been opened up.
Now, I inherited this car after it was replaced with a new VW SUV recently. The car runs and drives great, although there is some slight hesitation from the transmission around 2500 RPM. That, and I am getting a rhythmic sound when driving, which makes me think a wheel bearing is on the way out.
Glad to be here.
Old 04-30-2018, 06:55 PM
  #247
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
05 E500 Wagon 4Matic 161,300 miles. All original. I have had this car for 4 years. The two biggest expenses thus far were my initial A service with my local dealer so I could develop a relationship with them.....then $500 for MBstar set up so I would never have to deal with them again. (I got charged $35 for resetting the TPMS...which this VIN is not optioned with. There was a short argument)
To date - This is the best "all around" car I have ever owned. I'm a single dad so when I had to put away the toys...I got the wagon which is peppy enough and holds seven. I'm looking for another very soon to build my fleet of estates.
Old 04-30-2018, 07:45 PM
  #248
Shack1's Avatar
06 E350
My 06 e350 bought with 22k has been as “**** box” 47k now and balance shaft replaced now transmission control plate throwing codes. F me!
Old 04-30-2018, 09:45 PM
  #249
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
How long ago did you get it?
Old 04-30-2018, 09:53 PM
  #250
Shack1's Avatar
06 E350
2009 with 22k in mint condition, granted this was the worst year in history for MB
Quick Reply: Who has over 100,000 miles on their gasoline W211?
