Diesel Filter for 2009 e320 bluetec with U41
I just got a used 2009 e320 bluetec with U41 fuel water separator and lubication package with about 50k miles. There no record of a fuel filter change. It was a CPO car, before I bought it.
What is the filter part number for bluetecs with the U41 water separator?
What is the SA code if it has the heater in the fuel filter?
I had car MBZ dealer pre-purchased inspected and he did not think the fuel filter or tranny were serviced. How long can the fuel filter go without servicing -- will the water light go on?
dave
BTW shell ATF 134 for $55 per case.
Best to supply the lub. people the diesel engine oil cause they might use a syn oil with high ZnPhos.
I'm sorry I don't have the part # - but I was able to find them easily at Advance Auto Parts.
Simple DIY change, just leave the key in the run position for a few seconds after so that the electric fuel pump has a chance to fill up the filter. You might also need the CLIQ type clamps - as they are not intended (but can be) reused. Some have replaced with regular screw clamps without ill effect, although MB does not recommend this.
If you have a 642 engine(Bluetec) with a central located fuel filter with CODEU41(Fuel/water seperator and lube package)----then is that the code you are looking for. The heating unit is intergral to the condensation sensor
If you see an R54---that is the heating element for the fuel preheating system,less the condensation sensor.
FYI you can't have both you either either have U41 or R54
Doesn't have the R54. Has U41, the water sensor is 0001539513. The whole of the water sensor is in the center of the filter, so the filter part number is 6420920101 ?
I appears that the filter is 8000 miles over due. What sign will it have to change the filter?
My toyota mech. for my Sienna says change the spark plug when need not at the 90k mile schedule. It's 150k miles now and still the original factory spark plug change.
2009 e320 bluetec is the V6 with DPF and no urea system. The series ran from 2007 to 2009. None for 2010 and then 2011 e350 bluetec with urea system. BTW: No under dash cabin filter.
Read the owners manual and follow the manufactures schedule.
whunter@pelicanparts.com
Where do you get you car serviced and how do you like their service?
MBUSA offers many free documents you may find helpful or interesting.
https://www.startekinfo.com/StarTek/...tedDocId=50857
https://www.startekinfo.com/StarTek/...tedDocId=10458
https://www.startekinfo.com/StarTek/...stedDocId=9511
32+ years master mechanic in Detroit Michigan area, nobody but me touches my personal vehicles.
It funny that the very large local MBZ part department said the use Mobil 1 full synthetic and not Mobil 1 ESP or Euro type full synthetic for the bluetec. US Mobil 1 is about 1000% over spec for Phosphorus 1.0% versus 0.05 to 0.09%. What do you use?
I was wondering if Chevron DELO 400 LE CJ-4 is okay with slightly higher (20%) in Sulfur, Phosphor, sulfated ash that 229.51 spec. to the DPF and other Emissions components. The dino ISOSYN HD DELO are known to go over 50,000 in big rigs. Is the OilServiceInterval of 10k miles in the bluetec due to lubrication failure or too dirty for the DPF?
dave
Where (what state) was the CPO mercedes regristered?
I heard of people empting the tank and power washing out the tank. Since your is a CPO, the algae issue may be covered. What brand and type of biocide did you use?
I've heard that USA was behind EU due to the prior high sulfur in the diesel. Thus mercedes diesel delay for the DPF and urea injected bluetec in the USA.
Check the boards for info on biodiesel and issues that it create. Have the documentation before you speak to the MB-USA repressentative. Be nice, they may do it as goodwill.
"B5 biodiesel Mercedes-Benz USA, LLC approves the use of
B5 biodiesel (standard diesel with a maximum of up to 5% biodiesel content) in all Common Rail Injection (CDI) and BlueTEC diesel engines. Diesel fuels containing a higher percentage of biodiesel content will cause
damage to your engine and are not approved. Biodiesel can be refined from a variety of raw materials which may result in widely varying properties. Only use approved biodiesel. Approved biodiesel meets the ASTM D6751
standard and has the necessary oxidation stability (minimum 6 hours, proved with EN14112 method) to prevent deposits and/or corrosion. The use of non-approved biodiesel may damage the fuel system. Please ask your service station for further information. If the B5 biodiesel blend is not sufficiently labeled to clearly indicate that it meets the above standards, please do not use it. The Mercedes-Benz Limited Warranty does not cover damage caused by the use of fuels..."
My diesel is ULSD and has a slight odor like gasoline. I didn't notice that smell until the ULSD change over.
Fuel lubricity is important in all diesel fuel injection systems, many of the internal components are lubricated by fuel.
Bosch VE and VP44 pumps, used from 1989-1993 and from 1998.5 to present, respectively, are lubricated by fuel only. The Bosch P7100 pump, used from 1994 to the first half of 1998, uses engine oil to lubricate some of the pump, but fuel lubricity is still significant. When the US EPA required lowering sulfur content of diesel fuels, there was widespread concern about lubricity. It turned out that if the fuel was not excessively desulfurized the lubricity was usually sufficient, or could be made so with an additive. Hence, lubricity should be monitored closely by refiners.
The aromatic content of the fuel is also reduced by hydrotreating (the process used to remove sulfur). In a few engines, fuel system seals swelled and worked better with highly aromatic fuels, but they tended to shrink and leak when the engines were switched to low sulfur, low aromatic fuels.
http://www.holt.us/tdi/index.html
