E-Class (W211) 2003-2009
HELP FOR NEW MEMBERS ABOUT FUEL SENDING AND FUEL PU,
Old Jul 15, 2013 | 06:26 PM
ErlingManuel's Avatar
e320 2004
Smile HELP FOR NEW MEMBERS ABOUT FUEL SENDING AND FUEL PU,
Hi forum friends I have a problem with a 2004 mercedes e320 happens if it was from my father recently died, the car was in the house kept it decided turn to warm, then the car will not start, to check the car has damaged the fuel pump and fuel sending apparently broken in the hose that goes to the inyectore been checking it on the web to buy the filter and the fuel pump but I have a problem is that the pump everything right in order that i found a good original price but not doing the work the fact is that with the fuel sending my part number is 211 470 15 41 but apparently that part number is discarded and is now used 211 470 4094 but I have fear buy because the connectors do not look at anything I read you have to use some adapters and let me know how easy it is to connect with aDAPTERS, I'll post the part number I need to connect the fuel sending would check it right thanks
adapter 211 440 05 07
211 471 12 41
mi old fuel sending
http://postimg.org/image/qqbpn0m1h/5170dbb6/
and the new fuel sending
http://postimg.org/image/rya50uc1r/bc47d0f5/
sorry for my english salut from dominican republic
Old Jul 16, 2013 | 10:19 AM
e320 2004
Hi mi vin number is
WDBUF65J74A521218
thanx you
Old Jul 16, 2013 | 11:20 AM
konigstiger's Avatar
'71 Pinto
http://www.benzworld.org/forums/w211...gas-smell.html
Attachment confirms part #s are correct in addition, took the liberty of attaching vehicle datacard.
File Type: pdf
File Type: pdf
Old Jul 16, 2013 | 12:51 PM
e320 2004
Thanks for the help all parts confirmed right now I have a doubt the connector 211 440 05 07 as the wire is connected to the car since my car does not have the connecting plug that goes to the ecu the car would have to cut the wires and splice the wires from under the seats ..
assemble the pump and filter so complicated no dealer in my country wants 2500 dollars, which is harder to get the hose in the tank with a wire but can only make a guide and guide the wire
As Electric Splice connector of the wire under the seat coming .. color to color ... or if you have any diagram I would appreciate my car tieen not entering the adapter plug
Need recalibrate the sending unit? how can i do that..?
I have not got this plug that goes into the car where the wire connects to the ecu
http://postimg.org/image/5xbd7ptdp/
Old Jul 16, 2013 | 12:55 PM
e320 2004
The leak of my car
http://postimg.org/image/8n1qrgl09/9097b1fb/
