E-Class (W211) 2003-2009
Need bluetec informations
Old Aug 2, 2013 | 05:59 AM
Bluetec.'s Avatar
E300 Bluetec
Angry Need bluetec informations
HI, i have an W211 bluetec nad i want to know how bluetec works on my car, how regeneration process works and i want to know if i have to replace my bluetec filters, DPF or smth else because i have now 110.000 miles. pls I have searched on forum for bluetec i have took some informations but not what i really need to hear from you guys. Also i have some leak of power... when i'm stopped and i kickdown my throttle the car 0-100 time is 9 sec, while she is accelerating in first gear, 600rpm to 2000-2200 rpm is to slow very slow...is this a problem?
Old Aug 2, 2013 | 12:26 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec (retired)/, now 2012 E350 4-matic blueefficiency automatic
The dpf are regenerating by long highway drives with the coolant temperature above 80C. If below 80C, check the thermostat. Try that first. Then there are regeneration solutions and physically cleaning the dpf, which I lack the experience. Search this site for more information on dpf regeneration and diagnosis. Also check the warranty -- it still might be active.
Old Aug 3, 2013 | 12:22 AM
pinebaron's Avatar
07 E320 Bluetec
Some useful information
The information may not be unique but I believe it answers your questions if you read the entire content.
http://www.rbmpartsnews.com/Articles/Bluetec
Old Aug 3, 2013 | 05:26 AM
Bluetec.'s Avatar
E300 Bluetec
Thank you, i took some info that i needed but i didnt find what to do after some miles because i have read smth that the bluetec catalytic needs to be replaced for 100k-150k miles
Old Aug 22, 2013 | 08:36 PM
do a search with using cdi instead of bluetec. the W211 did not the urea bluedef and commonly listed as cdi. I recall a thread of the problem your car has, but not the details. I don't know if it was mbworld or another benz site. tray googling it. the cat usually will cause higher back pressure. I think there are some ports before and after the cat to measure the pressure.
