gased it, and won't move "help"
04 E500 Pewtergrey/ 06 E55 AMG White
I have mentioned this before guys, but I will try again. When ever I am on the freeway or streets and I decide to floor it (gas to the floor) punch it, whatever they call it. The benz stalls and does not go anywhere, even while holding or pumping the gas pedal to the floor. this happens for sometimes 5-8 seconds, and than power restores and off she goes.
Could this be the CPS?
Their are no code on my car, so I'm puzzled, this happens on the freeway when i am getting on the freeway and than gas it hard to increase speed, than it coast with no power and scares the living hell out of me or when another car is tailing me and i gas it to move over and the same thing again.
somebody got to know the answer. Thanks
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
The problem is not as simple as you think that system is complicated, but it sure aint the CPS. Spend some money on a good scan or have you kids drive you around!!
06 S211 E500 4Matic
Not CPS for sure. Does sound like accelerator related. Do you press that small button under the pedal? What I mean by that when you press the pedal hard enough you can feel it. That point throws accelerator to WOT (wide open throttle) and kicks the transmission in lowest gear possible.
Thanks for your response, but I fixed it this morning at my local indy. But Quadcammer and You were right. after I found this thread, I went to my local indy and all was fixed.
https://mbworld.org/forums/e-class-w...al-sensor.html
better throttle response and now i can pucnh it without worry, thanks
