E-Class (W211) 2003-2009
Air Conditioning with a mind of his own !!!!
Old Aug 14, 2013 | 04:10 PM
gucrosusa's Avatar
2004 E 320
Good Afternoon
The AC in my 2004 E320 is driving me crazy.
All the lights in the control panel work properly (change in intensity, AC on, direction of flow), but the $#$@% starts and stops whenever it feels like.
To make matters worst sometimes when I turn off the car the blower still keeps running for about 1 or 2 minutes..
It's 91 degrees here in Miami most of the days and I really need this working.
I wonder if is just a matter of refrigerant level or the regulator?
In a visit to my indie shop (ex MB Mechanic) they hooked the computer to the OBD Port and they tried to control the AC with no avail. It showed full blast but was dead.
Please Help !!!
Old Aug 15, 2013 | 12:02 PM
E500 AMG Sport's Avatar
Sounds like a bad blower motor regulator...
Common issue on Mercedes...
Easy fix, do it yourself.
Old Aug 15, 2013 | 01:00 PM
gucrosusa's Avatar
2004 E 320
Thank you very much for your response !!; I'll search for it and post the results.
Old Aug 16, 2013 | 10:47 AM
Barry45RPM's Avatar
2015 ML 350
On my '04, mine would stop blowing whenever the system was put on DEF, or went into the Highest Blower speed either automatically on demand from the system or by pressing a button.
It was a bad Blower Motor regulator... and it was a very common problem.
Old Aug 16, 2013 | 01:16 PM
gucrosusa's Avatar
2004 E 320
Thank you for your response; already ordered the regulator at http://www.autohausaz.com... just $ 105.64 including shipping, hope this works...
Old Aug 22, 2013 | 05:20 PM
gucrosusa's Avatar
2004 E 320
Talking
Good Afternoon
Received the Regulator today; 25 minutes later the AC is working like new!!!!
Thank you very much for all the help !!
Old Aug 23, 2013 | 12:18 PM
Feels good to save yourself money, doesn't it?
I suggest you also go ahead and order yourself a (Bosch) Crankshaft Position Sensor from the same place you ordered the blower regulator. This way you have it on hand when it craps out, as it's just a matter of time before it does.
Old Aug 23, 2013 | 12:48 PM
gucrosusa's Avatar
2004 E 320
Will Do, thanks for the suggestion. Now that you mention it,the ignition is beginning to act up. Sometimes When I turn the key I hear a click and then nothing, I believe this is exactly what you are talking about.
Old Aug 26, 2013 | 11:23 AM
Barry45RPM's Avatar
2015 ML 350
When my CPS failed, it presented as a normal crank no start codition. Leave the car alone for a bit to "cool off" and it cranks and starts normally. You may detect a stumble in the idle while waiting at a traffic light too, before it really fails.
