E-Class (W211) 2003-2009
Help with towing a 2003 e500 on a two wheel dolly
Old Aug 28, 2013 | 03:39 AM
john0183's Avatar
2003 E500 sport
I am going to be traveling about 1700 miles and need help on towing my car on a two wheel car dolly . Would it be ok if I to it with the rear wheels up on the dolly would it damage my transmission thanks and would I have to disconnect the driveshaft and does anyone know how to do it if I need to to disconnect it. Thanks help would be appreciated .
Old Aug 28, 2013 | 09:22 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Is it 4-Matic or RWD? If it's 4-Matic all wheels need to be lifted or you will damage the transfer case and transmission. If it's rear-wheel-drive then you can lift only the two rear wheels and you will be fine as with any RWD car, there is no power sent to the front wheels. Look online for further towing instructions and guidelines.
Old Aug 28, 2013 | 09:28 PM
john0183's Avatar
2003 E500 sport
Rear wheel drive
It's a rear wheel drive I hear that u can't put the rear wheel drive on a dolly or else it will move back and fourth because of the weight in the front I am trying to figure out how to disconnect the rear transfer shaft I heard I can do it like that .
Old Aug 28, 2013 | 09:46 PM
2014 BMW M235i
If you're towing with the rear wheels on the ground, the drive shaft needs to be removed. If you are not towing it with the rear wheels on the ground, hence backwards with a tow dolly if you can do that with your setup, then no you do not need to remove it. I have no heard that but consider calling your dealership.
Old Aug 28, 2013 | 10:20 PM
john0183's Avatar
2003 E500 sport
Yea I am putting the rear wheels down and want to disconnect the drive shaft .
Old Sep 2, 2013 | 11:14 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
I'd suggest renting a car trailer. I've done this in the past and it was far better than a dolly.
Old Sep 3, 2013 | 12:20 AM
john0183's Avatar
2003 E500 sport
Yea I think I am going to get a car trailor but is my alarm going to be going off every 5 minutes .
Old Sep 3, 2013 | 01:08 AM
2014 BMW M235i
-Don't arm it
-Unplug the battery
-Take out the fuse
You have some options here bud. All of the above procedures for towing are described in the owners manual in the 460s pages. The engineers did not forget about towing.
Old Sep 3, 2013 | 01:14 AM
john0183's Avatar
2003 E500 sport
Thanks guys.
Old Sep 3, 2013 | 01:19 AM
2014 BMW M235i
For sure, let us know if you have any other questions. If you don't have a manual you can download one from the MB website
Old Sep 3, 2013 | 01:22 AM
john0183's Avatar
2003 E500 sport
I don't have the fuse diagram does anyone know where I can find it for a 2003 Mercedes Benz e500 sport with airmatic suspension .
Old Sep 3, 2013 | 01:45 AM
2014 BMW M235i
Search the forums. https://mbworld.org/forums/e-class-w...x-diagram.html
