E-Class (W211) 2003-2009
RUN FLAT INDICATOR INOPERATIVE
Old Sep 8, 2013 | 01:50 PM
akboss06's Avatar
E class W211 facelift
Angry RUN FLAT INDICATOR INOPERATIVE
Hi, I dont know what the problem with this car is Recently I see this eror on board I tried to reset but nothing had changed. What might the problem be is it about a sensor ? I checked with star but nothing appears no codes.
Best Regards
Old Sep 8, 2013 | 03:45 PM
konigstiger's Avatar
'71 Pinto
If message appears when braking “may” be intermittent fault with brake switch located top of brake pedal – part # 0015456709.
Old Jun 8, 2023 | 11:09 AM
luffy09876's Avatar
mercedez
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently; the ABS, ESP Malfunction, Run Flat Inoperative came out to my dash, I scanned it myself and found out that I had a bad ABS wheel speed sensor. I Immediately purchase and replace the wheel speed sensor myself, reset the code and it works normal now. I came across an in-depth article that may be worth reading. Search for "Run Flat Inoperative. ABS, ESP, Malfunction on Mercedes-Benz on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
