E-Class (W211) 2003-2009
Webasto remote isn't working on my E320CDI!
Old Sep 13, 2013 | 07:48 AM
the_engineeer's Avatar
-04 E320cdi estate
Hello all!
I have recently bought a 2004 E320CDI estate with factory mounted Webasto incl remote. The remote doesn't start the heater but it seems to work, I changed the batterys and it lights up the green/red lights when I press the buttons. I have read that the remote sometimes need to 'reconnect' to the car by unplugging the receiver in the car and then pressing the ON button on the remote.
BUT: Where's the Webasto receiver in the car?!
I can't find it or even find some info about where it is located on the E320 model...
Thanks for any help!
Old Oct 1, 2015 | 05:42 AM
nikkuu's Avatar
w211 E240
Did you find the receiver ? i have the same problem.
* i know it`s an old topic.
Yhamkyou
Old Oct 1, 2015 | 06:26 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Receiver unit (Telestart) is in the trunk, but webasto fuse is in the dash side fuse box and in W211 it also cuts power from telestart.
Remove fuse - wait at least 30 seconds - put fuse back and during 5 seconds press remote off button (at least 2m distance from car, you can cover remote with your hand to lower the signal).
Old Oct 1, 2015 | 07:03 AM
nikkuu's Avatar
w211 E240
You can tell me what number is the fuse ?
Old Oct 1, 2015 | 07:36 AM
mersum1es's Avatar
uh, I have a dim memory it would be #25.... its labeled on the fuse chart as a stationary heater or standheizung...
Old Oct 2, 2015 | 07:46 AM
nikkuu's Avatar
w211 E240
Thankyou,
Problem solved.
(take out the fuse put it back and it`s work)
