HELP 06 E500 Grinding at acceleration
Ok, so here is my story. If I am at a dead stop and I gradually accelerate I have no issue. However, if I am at a dead stop and I push the gas pedal too hard I will get a strong grinding/vibration sound. It stops on its own or immediately stops if I let off the gas. Now, if I am already in motion I never have this issue. And, if I start up slowly there is no grind.
When I hear the grinding/vibration there is no jerking, stuttering, or delays. It is just a grinding sound. Almost sounds like it is on the left side.
Also, there is no report of smoke or any burning smells.
If anyone can help I would greatly appreciate it. I'm actually losing sleep over this. Thank you MBW readers.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Very hard to diagnose from my vantage point, too many check this and check thats. My suggestion is put the car on a lift duplicate the sequence that produces the noise and then have the guy on the ground endeavor to locate the source----fix the source and carry on!!
GregK (05-01-2020)
i have that in my e55. When i stomp on the gas pedal, get a delayed grinding sound for a split second or so and then the car takes off. Got the front end checked and not wheel bearing. Not sure what it its either but doesnt sound right.
