E-Class (W211) 2003-2009
rear thunk in e500
Old Nov 13, 2003 | 08:51 PM
bmw2mb's Avatar
530
rear thunk in e500
someone posted a problem awhile ago about having a thunk sound coming from the rear when driving over some bumps in the road.
my car started this last week. in comfort mode, over some bumps, there is a thunk sound (loud, like bottoming out) coming from the right rear.
please post if you know what this problem is...i'm taking to the dealer soon but would like some way to point them.
Old Nov 14, 2003 | 08:56 AM
slipnby's Avatar
LEXUS
I had this problem most of the summer in my replacement 03 E. I thought is was my junk in the trunk. When I removed the junk the sound persisted. The dealer replaced the right rear shock, saying it had a defective spot, and now there is no more noise.
Old Nov 15, 2003 | 10:03 PM
jtc3's Avatar
E500
It was my post originally. Same fix, new rear shocks, the right one was the bad one but they replaced both. No problems since with the rear suspension.
Old Nov 16, 2003 | 06:46 PM
e500's Avatar
E500
Interesting. My '03 E500 replacement started making this sound about a week ago. It has about 3K miles. Sounds like someone underneath hitting the rear wheel well with a rubber mallet. Happens to be the right side too.
Old Nov 16, 2003 | 08:55 PM
NuBenz's Avatar
02 996 C2 Cabrio
Tell me this...
Do you guys notice this thunking sound when cruising over bumps? Let's say you coast over some lumpy railroad tracks. My car seems to thunk in the right front every once in a while when I'm coasting over tracks or speed bumps.
It only seems to occur if the car gets a little "bounce" to it... not exactly leaving the ground (Dukes of Hazard style!!!).
Old Nov 16, 2003 | 08:56 PM
NuBenz's Avatar
02 996 C2 Cabrio
What exactly was wrong with the shock? Can you elaborate?
TIA
Old Nov 17, 2003 | 07:45 AM
slipnby's Avatar
LEXUS
TIA
The tech said there was a weak spot in the shock mid-way and it was defective. I heard the thunk every time I rolled over a manhole cover, a ridge in the road, rail road track or pothole. The noise happened at speeds between 25 and 45. No noise at higher speeds.
