W211 Courtesy light problem
If so, chances are that the control/relay burned a trace and a diode inside the module.
This is a different scenario then I visualized!
First of all I would get myself new light bulbs according to Manuf Specs and insert them.
Check if you can get it to work correctly again.
If so, then my best guess is that the LED's don't draw enough current.
Everything nowadays is computer controlled or switched on and off.
The computer / control module may not see enough current to switch properly.
In the course of checking, swapping etc. your old bulb may have seen the dark end of the tunnel and doesn't want to come back any-more.
That's why I said to get a new one and try to get back to original state.
If it works again, then try the LED's again.
Many times the LED manufacturer forget to tell that LED's draw a lot less current and actually may trigger some fault in dash e.g. burned out bulb. The dome light is, I think, not in the loop, but may still be controlled by some module that doesn't switch.
Sorry about the above comment, that may not apply entirely to your problem.
