E-Class (W211) 2003-2009
Use your head - it works !
Old Nov 18, 2003 | 01:01 PM
marc777's Avatar
2012 CLS
Want to extend the range your remote control will unlock your car?
Use your head - its true.
Try it...........see how far back you can be where the range of the remote control fails. Then step back even further and place the remote control so it touches the side of your head - at the temple- and try it again. Now it works ! - Bizarre but true.
Anyone know why? Plese tell me if you know.
And if you don't believe me - just get out there and give it a try.
Marc
Old Nov 18, 2003 | 01:13 PM
lig's Avatar
lig
was '03 E320 - now - '04 S4
hehe... I put it right underneath my chin.
Old Nov 18, 2003 | 01:19 PM
Nanky's Avatar
2007 E63, 2007 BMW 335i Coupe & 1991 Honda Accord
I use the same trick when ever I have in weak battery in a remote. I don't know why this happens. Must be some energy from the body that boosts the battery charge.
Old Nov 18, 2003 | 01:26 PM
codex57's Avatar
03 White on Stone E320
hmm, never used it. Nevre had a reason to. My key works from like 80 yards away. Haven't tried further but 80 yards is far enough. I only need that trick with the BMW. Stupid thing has a range of like 3 meters or less. Still better than the Jeep Cherokee I once had. That thing had a range of literally one foot, and it had to be pointed through the window at the sensor. At that point, you might as well just unlock the car manually.
WhiteTrash's Avatar
2003 CLK430 Cabriolet
I read an article on this a while ago - the signal is amplified through your body or something - like a giant antenna. weird.
Old Nov 18, 2003 | 04:49 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
yea, your body acts as an antenna...for example. When you adjust the antenna on an old tv, when you touch it, it is clear picture, but once you leave, it goes back to static :p
-G-
Old Nov 18, 2003 | 05:06 PM
akmal31's Avatar
Re: Use your head - it works !
Marc
hey Marc.....I know where you got this info. from lolz!
Did Mr Clarkson not give a reason?
Old Nov 18, 2003 | 05:15 PM
sf49ers79's Avatar
Honda Accord EX V6
I put it on my head, too man!!
Old Nov 18, 2003 | 05:34 PM
bmms8's Avatar
MB
yea this is a cool thing to do. i put it under my chin. we were discussing this with other people, and someone said its possibly because there is iron in your nose, which will make the signal stronger.
Old Nov 18, 2003 | 05:45 PM
abhansali's Avatar
-G-
Ahh, reminds me of college and my rabbit ear antenna....
Old Nov 18, 2003 | 07:26 PM
RJC's Avatar
RJC
Various
I've found that just raising the remote high in the air increases the range . As far as touching it to your head chin etc and the TV antenna comp...once your hand is on the remote you're already in contact with it so further touching it to your head, chin etc should not really add more amplification.
Old Nov 18, 2003 | 08:59 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I've tried that from far away before (raising it in the air)...then I put it under my chin and it worked.
-G-
GDawgC220's Avatar
'05 A4 1.8TQM6
-G-
