emercnsy please mercedes limp mode problem
this 2 codes course limp mode
i change inlet manifold and checked egr valve
turbo valve works aswell
p2025 :
confused:
p0105
many thanks
what does mean b28/5 n3/9 b5/1
so do you think maf sensor or atmospheric pressure sensor can course this codes..
give me idea please what i need to check iam really in
do you think is can be that?
The generic code P2025 is for the evaporative emission fuel vapour temperature sensor - range/performance.
There is a thermovalve for the EVAP system which could be causing this fault but I don't know of its exact location.
evaporative emission fuel vapour temperature sensor where is this sensor on 2003 c 220 cdi?
could be to much black carbon in engine?
i changed inlet looks clean now''
thanks reyft
Remember we in the USA have not seen 211.008 therefore there will be no OBD faults you have Euro.
FYI my fault for b28/5 =23E6-000 and I have three fault codes for b5/1=201A-000;2017-000;201E-000
My advice is to follow what your tool says is the problem and fix!!
really thanks for interested
i found inlet manifold flab was really bed condition but i learned it is doesn"t course limp mode so..
i think you and i found the problem
how they calling this mercedes codes is it just for mercedes?
