E55 AMG where are the AC Filters? HELP!!
The Stealership is charging me $100 to replace the AC filter that is latched right on the cover from the auxiliary battery. That's so easy to replace and the filter cost like what $25 bucks. There crazy. But I NEED HELP are there any other AC filters? If there is how do I get to it. Do I get to it under the passenger? Ughh idk!! I NEED HELP 2005 E55 AMG 115K miles NEVER!!! changed AC Filters. Rarely use AC. I now need it for my grandpa to drive to DOCTORS APPOINTMENTS.
03 E500 and Corvette
IF you have the extra filters they are inside under the glove box. Use a flash light and look up from the bottom and you will see the two filters They are easily removed and dropped down. You will have to remove the plastic cover first.
I would double check, because the only two inside filters on your model repeat your model are the charcoal filters to the left of the blower and therefore would not produce a whiste-----FYI this is a double post!!
