Need location of 2007 E320 Bluetec oil drain plug
I've searched for ever and cannot get definite answer...do not want to drain wrong fluid
Many Thanks!!
Before I get into it...wish I could know for sure which drain to open.
Full disclosure...ha BMW 528i and drained transmition fluid...don't want to make that mistake again
You will have to remove under-shields to find the drain plug.
To be clear. The drain plug on this engine actually faces diagonally to the front/passenger side. You have to remove both front and back splash shields to access and drain.
Top extraction would be best with reliable pump!
