E-Class (W211) 2003-2009
Butterfly armrest broken.
Old Jan 21, 2014 | 04:42 AM
Nils Jensen's Avatar
E-280 V6 W211
The left 'wing' on my butterfly armrest doesn't open when released. Guess the spring came off or broke. The right one works fine. Does anyone know how I can remove the wing for repair - and if there is a replacable or fixable spring in there at all :-) Thanks in advance, Nils.
Old Jan 21, 2014 | 10:47 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Are you sure it's the spring. Last time I had that issue, it was caught on something (ie, something was closed in the mechanism). Careful, the wood caps are easy to break off.
Old Jan 22, 2014 | 06:19 AM
E-280 V6 W211
Thanks for your reply Boardboy330. Yes I am sure it is the spring as the wing just stays down and must be opened and closed manually. It's completely loose and without any resistance.
