E-Class (W211) 2003-2009
Error Code Help Needed
Old Jan 22, 2014 | 11:45 PM
Jack661199's Avatar
2003 E320 (W211) also starting to look for a CL55 or E55
I drive a 2003 E320 with 161XXX miles
I don't have any check engine lights on but I have 2 error codes
P0134 oxygen Sensor Circuit No Activity Detected Bank 1 Sensor 1
P0154 oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 1) Pending
So my question is what does "Pending" mean?
Do I need to replace both Sensors?
Also when I plugged in my engine reader my car came up as a 2003 E320 which is it but it also said it was a W210 does that change anything with it saying is a W210 instead of a W211?
Old Jan 23, 2014 | 09:08 AM
vettdvr's Avatar
03 E500 and Corvette
O2 sensors are like spark plugs. They wear out and need to be changed. At 161,000 if you changed them (4) out it would be a normal maintenance issue and might clear your problem.
