Temp Reading, Cold Weather
I could have sworn it always hovered around 90 to 100 no matter what the outside temp was before (but I could be wrong).
Do I have a thermostat hanging open (or opening early), or is this normal and just my memory is out of alignment.
If it is the T-stat, how hard are they to change?
Each drive was a bit over 30 min. There and back with a good cool off in between.
It got a little closer to 80 deg C when I pushed it, but the drive was mostly at 35 to 45 MPH on suburban roads.
Never crossed the 80 mark, and I swear it always settled above that after 5 min or so of driving.
SO on to the second question, how difficult is the T-stat replacement.
Saw a video on an '08 C-300. Is it the same?
Do you really need to remove the air pump, belt and idler?
Thermostat replaced. Car warms far more quickly now, even than it did earlier in the fall. So thermostat was probably hung open for some time, but it took the very cold weather to notice.
Still gets near 60 Deg C.
Parts come in next week.
2 1/2 hours in a cold garage.
About 1/2 hour was because it was the 1st time under the hood of this car.
About 1/2 hour was finding the right tool with my garage a mess.
About 1/2 hour was waiting for it to warm up to double check everything at 33 deg.
Next time on a warm day on the drive way will be a 1 to 1 1/2 hour job.
