E-Class (W211) 2003-2009
Airmatic compressor wire harness
Old Jan 31, 2014 | 09:09 AM
ingydrummer's Avatar
2005 E-500 4matic sedan
Has anyone tried to rewire the airmatic compressor from the engine bay fuse-relay block? Tracing back from the compressor to the engine relay block, the wire harness is so tight I dont think that I can repair the broken wires without removing the whole harness. Has anyone ever done this before? Without figuring out how to remove the whole harness I dont think this is possible without tearing apart half of the front of the car apart. Just throwing this out there?
Old Jan 31, 2014 | 10:53 AM
I thought that removing and replacing the whole harness (just to the compressor) would eliminate any further wire problems. Anyhow, you said you gave me the color and number of wires? I did not see that post. Thanks again for your thoughts on this.
Old Feb 15, 2014 | 11:59 AM
Plutoe, I finally fixed the problem wire. It was a wire on the smaller plug to the compressor. Thanks again for your help.
Old Feb 25, 2014 | 11:28 AM
Servellon's Avatar
Mercedes Benz E500 2005
Do you have any pictures?...im salvaging a car and i dont know the colors and numbers of the wires to the compressor and the valve unit....thank you in advance
Old Feb 25, 2014 | 02:42 PM
Hoping this will help you?Air compressor replacement instr..pdf
Old Feb 25, 2014 | 09:23 PM
Servellon's Avatar
Hoping this will help you?Attachment 280046
Thank you..but I need to see the colors of the wires that connects to the air valve..the other component next to the compressor...thank you thou
