E-Class (W211) 2003-2009
A/C "diagnostic mode"
Old Nov 23, 2003 | 12:48 PM
bmms8's Avatar
MB
I read this on the C203 forum i believe, but someone said that if you hold the "rest" button with the engine turned on, there is a submenu for the A/C. i did it, but it was real confusing, it changes the degrees, i guess it was celcius, but i wasnt sure. there are some options under it, but its real confusing, there is no description or anything, does anyone know what the menu does, and how to use it? thanks
Old Nov 23, 2003 | 12:51 PM
awiner's Avatar
2003 CL55 AMG
See my post here :
https://mbworld.org/forums/showthrea...threadid=28782
You may also be interested in the COMAND Diag mode ifno found here:
https://mbworld.org/forums/showthrea...threadid=28786
Old Nov 23, 2003 | 01:35 PM
bmms8's Avatar
MB
Originally posted by awiner
See my post here :
cool, thanks a lot adam. but on my diag mode in the A/C unit, the driver side temp shows 00, and the passenger sows 21. then, if i press degree down for the driver, it will go to 99, and the passenger will change, i believe it goes to 37 or something. is there any point in changing any of these? i havent tried the comand yet, but is there any point in changing any of the comand ones also, thanks!
i tried doing the comand diag, but it wouldnt work, awiner do you know the buttons that i need to press, i think its because we have different comands, thanks, btw, how did you learn all of this, its real interseting.
Old Nov 23, 2003 | 02:08 PM
etenn's Avatar
E-500
Interesting....wonder if the comand diagnosis mode could yield information as to who has the latest software updates for the various problems we talk about on the W211?
Maybe someone with an update that solved a problem could post the version and others could check to see if they have that update.
______
Ed
Old Nov 23, 2003 | 02:53 PM
awiner's Avatar
2003 CL55 AMG
You can't change any of the values via these diag modes, they only display information.
Old Nov 23, 2003 | 03:59 PM
etenn's Avatar
E-500
I think everyone can understand that you can't change the values.
I was referring to the fact that often we see posts where someone has had a problem resolved by an flash update on the software.
The problem we usually have is not knowing what version we may have...and if the update would help us.
I wonder if we can compare our version with the updated version when someone posts an flash update.
Old Nov 23, 2003 | 04:16 PM
etenn's Avatar
E-500
See my post here :
I had no problem in accessing the AC diagnostic mode.
I could not access the Comand diagnotics.
I have a 2003 E500 with Navigation.
With the radio on and playing and the radio station displayed on the screen.
I press and hold the "Mute + 1 + 3" key at the same time. Nothing changes and I continue to have the same screen displayed.
Where am I going wrong?
______
Ed
Old Nov 23, 2003 | 06:06 PM
bmms8's Avatar
MB
______
Ed
i think its different because awiner has a different comand.
Old Nov 23, 2003 | 06:08 PM
etenn's Avatar
E-500
bmms....can you get it to come up? You have the same replacement Nav E-500 as I do.
_______
Ed
Old Nov 23, 2003 | 06:10 PM
bmms8's Avatar
MB
_______
Ed
lol, we posted at the same time it didnt work for me either, but i think its because awiner has a different nav system. how does he know all of this stuff!
Old Nov 23, 2003 | 06:17 PM
etenn's Avatar
E-500
I think you are right. Maybe he can enlighten us.
Anyone know how to access this on the W211 comand?
Old Nov 23, 2003 | 07:21 PM
awiner's Avatar
2003 CL55 AMG
You may have to try a few times to get the Mute+1+3 working. I have tried in on a '04 E500 and it works.
If you hit the buttons right, you should be presented with the 1st diag screen in approx 5 seconds. If you don't get the screen, try again.
Old Nov 23, 2003 | 07:44 PM
bmms8's Avatar
MB
i tried this several times, but i still cant get it to work. do you exactly know what screen i have to be in. i tried it several times in many different screens, thanks, and it should work on a 03 nav right?
awiner, howd you learn of this feature?
Old Nov 24, 2003 | 12:39 AM
etenn's Avatar
E-500
I also have tried several (many times) and nothing.
1. What screen should be showing when you start?
2. You say "if you do it right..." What would be right and wrong?
3. I simply hold down the 3 buttons at the same time. Is there a proper order or timing?
_______
Ed
Old Nov 24, 2003 | 09:38 PM
etenn's Avatar
E-500
Has anyone with the Nav replacement been able to access the Comand diagnostics described here?
Bmms8 and myself can't get it to work.
Old Nov 24, 2003 | 10:44 PM
alewifebp's Avatar
2014 BMW 550i
I got the A/C mode easily, but could not get in to the COMAND mode. Tried several times. Each time, it either muted the stereo, or programmed in a new station.
Old Nov 25, 2003 | 12:17 AM
bmms8's Avatar
MB
yea same with me, it has to be different #'s, i tried every # with mute + 1 but theres no way im gonna try them all:p
hopefully awiner can enlighten us
Old Nov 28, 2003 | 03:51 PM
alewifebp's Avatar
2014 BMW 550i
Anyone have any more info on this?
Old Nov 28, 2003 | 04:29 PM
bmms8's Avatar
MB
i still cant get to work, i tried pming awiner, but i dont think he set the pop up box option.
Old Nov 28, 2003 | 05:44 PM
Legacy's Avatar
COMAND Diagnositics Menu
I was also able to easily access the A/C diagnostics "menu" with ignition on and engine off.
After a few tries I gave up on the COMAND diagnositics search. A bit frustrating, but I am not yet sure it is available on COMAND II system at least using the same entry method.
Some further info and/or enlightenment would be helpful.
