Changed rear air bags and display says check rear with arrow
2003 E500 sport
Hey guys I changed my rear air bags to arnott a-2724 bags for rear and it still says check rear air. Suspension with the arrow so I checked with an ob2 scanner and could read it but I cleared the code and hasn't came up back up any suggestions because it was saying it before the rear was replaced .
2003 E500 sport
I had a rear Airsuspension error message because my original bags were leaking so then I replaced them with arnott air bags and the error message wasn't. There and then popped up so I used an ob2 scanner and reset the error message I am trying to know if anyone might know what could have caused this error message thanks.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
If you didn't clear the first fault that was caused by a leaking OEM bag that fault would still reside in memory regardless of who's brand installed---then you went back and cleared the fault----sounds normal to me.
