E-Class (W211) 2003-2009
problem with my antenna and heated seats??
Old Nov 24, 2003 | 01:50 AM
TectiteE's Avatar
MGT, 12 CLS63 Launch
for some reason when i turn on the rear window defroster, my radio gets very very staticy and goes away when i turn it off. anyone have this problem? also when the heated seats are turned on with all three bars showing i notice after awhile it drops down to two bars then 1 bar autoamtically. is this normal?
Old Nov 24, 2003 | 05:47 AM
Redryder's Avatar
2025 GLC 350e
Normal for the seats to reduce in heat. It takes about 5 min for mine to go from 3 to 2 bars and then another 5 and it's down to 1 bar. The radio - sounds like a problem to me. If it happens all the time, you probably want to take it in. Good luck.
Old Nov 24, 2003 | 07:15 AM
MadManAboutTown's Avatar
2004 E500
I would guess that it's an antenna problem, so ask your dealer to check it out.
Old Nov 24, 2003 | 12:22 PM
akmal31's Avatar
The heated seat thing is th way they are......It goes from 3 lights to 2 in 5 mins and then from 2 to 1 in 10 mins and then from 1 to none in 15 mins....so the heated seats stay on for 30 mins
