E-Class (W211) 2003-2009
LEFT REAR SPEED SENSOR
Old Mar 3, 2014 | 12:40 PM
iulianpopa's Avatar
e 320
somebody know how to verify the rear speed sensor if it's ok or not?
thanks
Old Mar 3, 2014 | 01:19 PM
iulianpopa's Avatar
e 320
thanks, but what is this ...DAS Xentry
I don't know if I have to change the speed sensor or the magnetic reluctor,
rear left side
Old Mar 3, 2014 | 01:50 PM
iulianpopa's Avatar
e 320
For all these reasons I’m suspicious, he’scomputer says is the speeds sensor, he order the part, (260$) he check with a smallflashlight the ring, he told me is the ring not the sensor, but he never checkthe old sensor, (he return the new sensor) so I have to take one more appointment, 4h to change the ring, (he told me that)maybe after that I have to change the sensor also???
Old Mar 3, 2014 | 02:32 PM
iulianpopa's Avatar
e 320
Your logic is faulty (HE'S LOGIC IS FAULTY) --an MB speed sensor costs about 150.00, not 260.00 he is ripping you off (WHAT I BELIVE) ----second to replace a speed sensor is cheaper that replacing a reluctor ring (I AGREE WITH YOU) ---why would you replace a reluctor ring before changing the speed sensor, which testing has proved to be bad---what is wrong with this picture???
First change mechanics to one who works on MB's (I WILL DO IT) and understands the systems!! You will live longer!! (I HOPE)
PS: You can do a continuity test to test the sensor---if you do not know what that is do a google search!!
thanks for your time, have a good one
__________________
Old Mar 3, 2014 | 03:53 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Just take the car to another independent shop with DAS Xentry, have them test it, and get a quote. Sounds like someone is trying to make profit off of your little speed sensor issue. Maybe that included labor?
Old Mar 3, 2014 | 04:31 PM
iulianpopa's Avatar
e 320
today it's hard to find a honest mechanic, I appreciate your help guys
Old Mar 4, 2014 | 07:04 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
As I said in your other post............ It is hard to believe that the reluctor ring will go bad unless some type of work is been performed on the half shaft. It will take lots of road salt to damage it, but then you will also have damage to other parts in that hub if this is the case. I would say that you are better off if you get the whole half shaft, just to be on safe side and not having any future problems (like slipping ring because of worn shaft).
But like every one say: get second opinion. And don't abandon your old tread and starting new one to ask same old question just because I said something that 99% of the people reading it won't know what means, please.
Old Mar 6, 2014 | 10:53 PM
iulianpopa's Avatar
e 320
I change the speed sensor, I erase the code with the ODB2 for check engine, I drive the car for some 30 Km, and the check engine is coming back, P0500, speed sensor a,
ABS and ESP still on, malfunction visit workshop, also abs yellow light on dash is on,
I forget to tell you the guy who check my car find also the error code in break control unit (the piece who is waranty 10 years) my car have 10 years and 6 months....
I think the next step is appointment to the mercedes dealer
Old Mar 21, 2014 | 08:10 PM
iulianpopa's Avatar
e 320
finaly, Mercedes dealer blainville (north of montreal) fix the problem, they change the magnetic ring, everything is ok 20$ the part, 3.5h work on my car,
Old Mar 21, 2014 | 08:15 PM
isstay's Avatar
So it was not that bad at all to go to the dealer, should do it in first place and not spending money on all those indy shops. Glad it is all over.
