E-Class (W211) 2003-2009
"Service Break Visit Workshop"
Old Mar 5, 2014 | 11:27 PM
Kanwar H Singh's Avatar
Angry "Service Brake Visit Workshop"
I have 2006 E-350,Front brake pads and sensor changed two month before, now got this message, changed rear pads and sensor still message is their.Help me Thx
Old Mar 6, 2014 | 10:30 AM
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by Kanwar H Singh
I have 2006 E-350,Front break pads and sensor changed two month before, now got this message, changed rear pads and sensor still message is their.Help me Thx
If the car is braking fine then it could be the brake light switch. Search the forum for "Brake - Visit Workshop" and you may find instructions on how to replace the switch, apparently an easy DIY task.
Old Mar 6, 2014 | 04:07 PM
jimbo1763's Avatar
2007 E350 Sedan
https://mbworld.org/forums/e-class-w...-easy-diy.html
Old Mar 6, 2014 | 04:36 PM
OnlyGerman's Avatar
Too many german broads
Had the same issue after, it was the switch..
Old Mar 21, 2014 | 01:55 AM
Service brake visit workshop
Change brake light switch but message is still their any help pls.
Old Mar 21, 2014 | 02:43 AM
SorryAboutThat's Avatar
2018 C300 Coupe
Change break light switch but message is still their any help pls.
Another thing to check would be to make sure you have the proper brake fluid level. Anyone know if low fluid level triggers the white "service brake visit workshop" message?
I recently had the same message and replacing the brake light switch didn't resolve the problem. It turned out to be the faulty SBC pressure reservoir that's attatched directly to the SBC hydraulic unit. I have seen some people call it an SBC accumulator as well. The dealership got code #C2131 and it was a US$1400 repair. A local independent MB only mechanic didn't want to touch it...too much liability he said...so a dealership repair job was the only option I felt comfortable with.
Sounds like the next step for you should be to get the code read by a DAS/Xentry diagnostic. Good luck....and sorry about that!
Old Mar 21, 2014 | 01:48 PM
"Service brake visit workshop"
New brake light switch , Brake oil level good----still has message. any other suggestion THX
Old Mar 21, 2014 | 03:32 PM
2018 C300 Coupe
You've tried the "easy" solutions already so it's time to go get the code pulled somewhere by a STAR diagnostic. Anything else is just guesswork at this point. I understand your reluctance but this is a potential safety issue so please get it taken care of. (Hurry, before Plutoe sees this thread lol)
