E-Class (W211) 2003-2009
STAR LOWERED ISSUE PLEASE HELP
Old Mar 17, 2014 | 03:54 AM
Inspiredbenz's Avatar
SOLD W203..CURRENTLY DRIVING W211
Hey their im star lowered and if i leave it parked for overnight rear saggs..anyone having an issue like mine ?I never had sag issue before it was only after i had gotten car lowered via star !! Maybe person didnt do star correctly?
1)Now if im driving with passengers and park the car it does not sagg overnight stays at same height
2) if im driving alone car is sagging the next morning and if i press the unlock button or open the trunk or even any door i can see the rear lifting up with out the car being started
Does any one have an issue like mine ?
Old Mar 17, 2014 | 08:45 AM
vettdvr's Avatar
03 E500 and Corvette
You have a leak.
Old Mar 17, 2014 | 01:34 PM
Plutoe what do you mean by start?
Old Mar 17, 2014 | 01:35 PM
Vettdvr- if i have a leak why doesnt it sagg the night passengers were sitting in it
Old Mar 17, 2014 | 02:28 PM
Lol makes more sence now
Old Mar 20, 2014 | 09:05 AM
vettdvr's Avatar
I found the air bags can develop a very small crack in the fold. While running the compressor can put in more air than leaks out so it stays up. When empty not running the change in temps can cause the air in the bag to expand or contract and open the crack. IF the compressor is active it will maintain level. If not it will leak down. I have had cars with air suspension since 84 and seen this happen many times. It is also possible to have a hose to the accumulator leaking due to corrosion. So it is possible.
90% of the time what I find is a airbag/air spring failing. After you drive a while the crack will open up and the compressor will run longer. IF it runs too long it will exceed duty cycle and burn out the compressor. Then you get to replace the leaky bag/spring and compressor.
This is for just one wheel leaking down. Consider on the rear both airbags/springs are the same age. The extra weight with one begins to fail will pull on the other bag/spring the same age and can quickly cause it to fail. This is why when you have a defective air spring/bag replace in pairs.
Arnott is a good supplier of these parts and my E500 had Arnott's on the front.
