E-Class (W211) 2003-2009
Voice Command Not Working
Old Apr 5, 2014 | 07:23 PM
Long Islander's Avatar
2018 E400 4matic Wagon
Since the voice command has very limited usefulness, we haven't used it in years. Nonetheless, you can use it to dial phone numbers, so I tried using it today to no avail. While the car is running and the Command screen is on (playing a CD), I tried pulling the stalk toward myself, but it doesn't "beep." Hence, it doesn't respond to any commands. I checked all the fuses and they are all fine.
Any ideas? Thanks.
Old Apr 5, 2014 | 08:36 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Any ideas? Thanks.
My 2008 GL does that same. (I have heard the module is essentially the same).
Mine died some time during the previous owners time, but he never used it so did not know.
I have been told I need to buy a new module, but have not bit the bullet yet. (ebay module is the same as the diagnostic fee, so I am still just guessing)
Old Apr 6, 2014 | 10:25 AM
Hmmm. Great quality control. Something that I used maybe 5 times goes dead. And to top it off, it probably went dead while my car was still under warranty but I didn't even know it. Where is the module and is it easy to swap out?
Old Apr 6, 2014 | 11:00 AM
N_Jay's Avatar
It is easy to sway out, but I don't know where it is on an E. (Our E does not have VC)
There is a write-up somewhere that tell you how to add it, so that would show where the module is.
Old Apr 6, 2014 | 12:02 PM
konigstiger's Avatar
'71 Pinto
DTB P-B-82.70/675 released 2/09 MY08 221 & 219 produced between 5/1/07 - 11/30/07 defective unit installed at production (hardware error), replace CU. Check your PM.
Old Apr 6, 2014 | 12:32 PM
N_Jay's Avatar
Any chance this would apply to a X164 in the same time period.
I am very sure the hardware module is the same (even if the SW is slightly different)
Old Apr 6, 2014 | 05:52 PM
'71 Pinto
Any chance this would apply to a X164 in the same time period. I am very sure the hardware module is the same (even if the SW is slightly different)
164.822 does have same VCS CU and part # is current but no notes in EPC (i.e.: applicable bulletin) 82.70/675 only applies to 211 & 219.
