E-Class (W211) 2003-2009
E63 amg
Old Apr 8, 2014 | 08:03 PM
Primus63's Avatar
05 E55
E63 amg
What's up guys, so my car has been sitting for about a month an I never started it so I try starting it an my key doesn't seem to be be working meaning when I put it in I can't turn as if I want to start the car. So I have it charging with a trickle down charger cause the car is in the backyard an I have no way of getting another car back there, is it just the battery in the trunk is just to low that why the car isn't recognizing the key? Thanks in advance
Old Apr 8, 2014 | 11:00 PM
AMGAffalterbach's Avatar
2014 BMW M235i
The batteries in the key fob could be too low or the car battery in the trunk could be too low. A good way to test it is try to put on the emergency flashers, if they're dim or blink really slow then you'll know the battery in the trunk is bad. I remember having this happen when a stuck relay for the compressor pump drained my battery.
Old Apr 13, 2014 | 10:16 AM
Primus63's Avatar
05 E55
Thanks it was the battery
