Transmission Problem
now the car goes into gear for may be 3 seconds, move may be 5 feet and then it goes back to neutral. I install the filter back but it is doing the same. I also replaced the conductor plate in late December.
Please HELP
when I was changing the sleeves with the new Sonnax sleeves, I accidently swapped the 72.6 (command valve "3-4") with 72.7 (shift valve shift pressure "3-4").
Yes, he did check ECU and transmission and there was no FAULT, everything was checked. He checked the Solenoids current and pressure.
