Airmatic Error Code 5503
Car does not raise up or lower itself once the message pops up after driving. Message goes away and suspension works fine once it's restarted.
Anyone here had this issue and was able to resolve it?
You should spray soapy water on the bags (car set to lifted point) to see if there are any leaks in the bags and connections. If you don't find any, then it is the compressor. BTW, I changed mine to an Arnott.
My W211 also has Airmatic (knocking on wood), it is still working well.
I think that you are right about the compressor. I just noticed that it does take quite a bit to fully raise the car now and one occasion, the car was rising with compressor working, but then stopped like half way up. Almost as if the compressor decided to quit from working overtime.
Replaced the air pump and the "Visit Workshop" message no longer pops up. So, just as 2.7Tallroader said, if you don't have any leaks and are getting the 5503 code, then it's your pump.
