E-Class (W211) 2003-2009
front wheel bearing hub assembly
Old May 28, 2014 | 04:49 PM
jte3470's Avatar
2004 E 320
Ok so I guess I'm going to have to change the front hub assembly. I suppose I could just change the bearings but I wanted to go with my dealers recommendation and change the entire assembly. Anyone have any tips for me before I start?
Old May 28, 2014 | 10:30 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
check youtube videos.
Old May 29, 2014 | 08:12 AM
vettdvr's Avatar
03 E500 and Corvette
1) the seal has the magnets for the ABS system don't substitute
2) The bearing has a chamfer on the inner side and don't substitute, over counter bearings won't have chamfer which will result in bearing not seating and failing
3) Buy OEM part and lubricant.
Old May 30, 2014 | 02:34 PM
jte3470's Avatar
2004 E 320
Well the part came in and I completed the job in about an hour and a half. It's suprisingly not all that difficult to do. I will say 2 things: unplug the SBC (it's a fairly easy process.) and insure you plug in the brake pad sensors correctly once you're finished. I did not get it plugged in correctly and once I started the car to reseat the brake pads; the car went crazy. That all being said; I appreciate all the help everyone on the forum has given me.
