E-Class (W211) 2003-2009
Did oil change!
Old Jun 15, 2014 | 03:14 AM
despicable merc's Avatar
E320
Did oil change!
Got car serviced. Changed the oil and now instrument cluster bips from time to time telling me to reduce oil level. Ihave a suspension they have put 9 quarts instead of 8.5 because i counted empty bottles there were 12 total in the box and 3 of those unopened. Now should i worry or let it go its only 1/2 a quart. And im not really sure may be the guy poured half out of the last bottle. Don't really trust electronic sensors... I did a few electronic measures through the menu and it told the oil level is ok but when I drive it beeps... Sometimes it beeps sometimes not.
Old Jun 15, 2014 | 08:20 AM
vettdvr's Avatar
03 E500 and Corvette
I changed my own oil and once got the same alarm after parking on a slope. If it is blinking but not staying on, I would just drive it and you will use a small amount of oil eventually and it will quit.
Old Jun 15, 2014 | 09:44 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I do 8 quarts per change...the sensor never goes off in either direction. I do not suggest you do this, just giving my experience.
Old Jun 16, 2014 | 08:38 AM
ibrian hb's Avatar
E320 v6 w21e320 2004 w2111 2004
yes to my experience 7.5 litres are good, i tried to add less than 0.5 litre it turned out there was 8.3 in the engine, either way its a risk you can take and im still trying to run the car in order for the car to use the oil and get lowered but next time ill pour 7.5 litres and add if its low.
Old Jun 16, 2014 | 11:11 AM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
I did the oil change 2 months ago, I did put 8.5 quarts at first, but end up taking out 1 quart. 7.5 is the correct level for my car
