Help: Replacing rear vents in console and can't remove ashtray
Perhaps the issue is that I can't seem to figure out how to remove the central consol storage bin liner. I can get a plastic trim wedge under the lip but can't figure out where it releases. It seems to slid under the trim toward the front, and pretty tight under the hinge for the cover. I'm pretty mechanical but this is very hard to figure out, at least in part because so many connections are hidden.
It almost seems like I have to remove the entire center consol to get to the rear nozzle eventually.
if you just take it apart, rather then fighting with it.
On the later console, you first have to remove the ashtray & gearshift surround....then you can
remove the section of the console that will allow you access the screw securing the lower
storage compartment/12v outlet.
But on the earlier console it looks like there are a few more steps involving removing the cup
holder, armrest lid & interior compartment separately.
http://bayhas.com/mercedes/w211/cont...terconsole.htm
