E-Class (W211) 2003-2009
Trunk Reset Question
Old Jul 7, 2014 | 10:23 AM
MTeezee's Avatar
2013 Mercedes S550 4Matic
My keyless trunk wasn't functioning properly and I was getting the license plate light and 3rd brake lamp message, etc.
I followed an earlier thread and went into the wiring in trunk. I reconnected the brown wire. Now I have power to the trunk but I cant open it with the remote or from the inside.
For some reason, I still have to use the actual key into the trunk. Do I need to do something else or am I missing something? Once in the trunk, the close buttons work to close it automatically. Any help is appreciated. Thanks
2008 E350
Old Jul 8, 2014 | 05:53 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Check the proper truck switch operation. In some older models, electric opening was disabled if car thought trunk was already open.
Old Jul 8, 2014 | 10:38 AM
MTeezee's Avatar
Clarification
Thanks mersum1es. Can you be more specific?
Old Jul 8, 2014 | 01:51 PM
mersum1es's Avatar
Trunk switch is inside the latch mechanism unless you have automatic trunk closing option. Here some info
https://mbworld.org/forums/e-class-w...e-my-w211.html
You still may have wiring issue, are fuses ok?
