E-Class (W211) 2003-2009
Easy entry not working anymore :(
Old Aug 10, 2014 | 10:55 PM
Big-poppa-dim's Avatar
03' E320 - Avantgarde
Hi guys , got a bit of an issue recently , I'm not overly fussed just upset that it no longer works.
When I put the key in the seat use to move forward and steering wheel would come down. The steering wheel still comes down but the seat no longer moves , and when I take the key out the stewing wheel moves back down but the seat remains in my memory normal setting. All the seat buttons still work fine , up down , back front. Just easy entry:exit stopped working , I unplugged the battery for 30 mins and reconnected .. Didn't fix it. My merc is a 03 e320 , avantgarde
Old Aug 11, 2014 | 07:30 AM
HardmanGT's Avatar
2005 E55 2005 E500 4Matic
have you checked your settings to see if it is enabled?
Old Aug 11, 2014 | 12:07 PM
konigstiger's Avatar
'71 Pinto
If feature is set properly (according to manual) try seat reset:
- outside vehicle / door open
- key to ON position 2
- move seat to furthest forward position, hold for 10 – 15 seconds
- press memory button you have your settings set to and allow it to adjust to set position
- get in while seat is in your set driving position, close door, then turn key to off position and remove
If this does not work find someone with SDS (independent, fellow member, dealer) to check/reset in addition, I believe an adjustment is available to increase furthest rear position back a bit more
Old Aug 11, 2014 | 01:38 PM
hangit06's Avatar
2006 E320 CDI
Will this also work with steering wheel position? Sometimes the entry feature works and sometimes it doesn't.
Also, is there a member list compiled of those with SDS and their locations that are willing to help fellow members?
John
Old Aug 11, 2014 | 03:01 PM
hangit06's Avatar
2006 E320 CDI
Wheel tilt works, but seat reset did not. Anybody with SDS close to Shawano WI?
John
Old Aug 11, 2014 | 03:24 PM
'71 Pinto
As of MY06 (with code 806, check your datacard), the Easy Entry/Exit feature is modified only the steering column will move.
Old Aug 11, 2014 | 05:16 PM
hangit06's Avatar
2006 E320 CDI
I also have 806. Seat no move!
John
Old Aug 11, 2014 | 06:47 PM
'71 Pinto
806 is year of modification = MY06, MB removed the seat feature for easy entry/exit in your vehicle you only having steering wheel feature.
Old Aug 12, 2014 | 01:03 AM
Hey, thank you very much for your feed back , I just got home and attempted the above 15 second reset thingy , sadly it didn't work ,
Is it possible to elaborate on what SDS is ? I'm in Sydney Australia and the dealers mb dealers here will tear me a new one just for a check up , is there any ways around that to have this issue resolved ?
Old Aug 12, 2014 | 09:07 AM
Barry45RPM's Avatar
2015 ML 350
Is it possible to elaborate on what SDS is ? I'm in Sydney Australia and the dealers MB dealers here will tear me a new one just for a check up , is there any ways around that to have this issue resolved ?
SDS is a laptop computer with software that allows MB Techs to look at every selectable/addressable programming choice (set-up) that's in your car. Cars in different markets operate differently to meet certain criteria or capabilities within a market.
With this computer, a tech can diagnose bad behavior or modify it to act like a car from another market. It can also be used to address the car's computer in a diagnostic way too.
Old Aug 14, 2014 | 11:55 AM
Ahhh yes is that what it's called , thank you for explaining it , my mechanic doesn't actually have one due to the price but he has a friend in hmtge industry with one of those pads , to hook it up is usually 110$ au each time ...
I guess I have no way around it so I'm willing to give it a go. Hopefully it will show the correct errors associated with the easy entry option.
