E-Class (W211) 2003-2009
Driver side door lock?
Old Sep 4, 2014 | 12:14 AM
ATXE500's Avatar
05 E500. 03ml320. 12 C250 CGI BLUE efficiency
let me start off by saying Hello.
this is my first thread and I love this site and in joy reading what's going on with everyone car and what mods/ repairs need or should be done.
So my main reason for this thing is that I own a 2005 E500 and I started having this door lock problem with driver side.
If I'm in the car with auto lock activated the door will lock but it bounces two or three times before fully locking?
Or if I'm trying to lock the car with the remote (door closed) the car will lock bounce a couple of times and will end up unlocked instead of locked.
Sometimes it works sometimes I have to grab the door handle to keep it from unlocking.
And the weird thing is that the other doors lock but the alarm won't activate so if I open the driver door the alarm won't go off and I know it had before and now it doesn't?
Anyone know if there's a door lock relearn I need to do?
Old Sep 4, 2014 | 09:07 AM
vettdvr's Avatar
03 E500 and Corvette
Replace the lock actuator. Some just need a bit of lube on the actuator. This is not a complex fix but does require pulling the door panel.
Old Sep 4, 2014 | 11:06 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
I'm not sure that this is the problem, but I'd try cleaning the parts (solenoids, position switches) with "precision electronics cleaner" and properly lubricating them. I recently fixed a complicated door lock system using this method.
Old Sep 4, 2014 | 11:54 AM
ATXE500's Avatar
Sounds ez! Thanks guys.
Old Sep 5, 2014 | 01:10 AM
maucca's Avatar
W211
Here's parts for bouncing lock actuator:
http://www.ebay.ie/itm/Mercedes-C-E-...item4185e11cbb
Old Sep 5, 2014 | 08:57 AM
vettdvr's Avatar
When I did my actuator the spring was not available as it is now in after market.
