E-Class (W211) 2003-2009
U0101 TROUBLE CODE
Old Oct 13, 2014 | 02:08 PM
Benzoid1's Avatar
2007 E350 Sport Sedan
U0101 TROUBLE CODE
My 2007 E350 throw a U0101 Lost Communication with TCM fault code out of the blue. Wife drove to and from work and the next morning the transmission would not shift past 1st. Did some research of the fault and the repair and the cost could be anywhere from $400 - $2000. I have a good indy mechanic that I trust but have anyone experienced this problem?
Old Oct 13, 2014 | 07:37 PM
Benzoid1's Avatar
Pulled the code myself, it's a generic code. When I talked to my indy mb mechanic he said that the most common for that code is a electrical conductor plate which is a common problem in 7G transmissions. That was the only fault that showed up. the transmission went into limp home mode. is there a specific code reader that should be used?
Old Oct 14, 2014 | 09:23 AM
Benzoid1's Avatar
The MB mechanic that I use is not a slug, he runs a reputable shop with 15 years experience as a MB tech. He was not advising but was implying that this was the most common problem with these transmissions and upon further research I found that this is true even in the early life of the transmission. Are you aware of this problem with the MB 7 speed transmission. Just doing my due diligence before I take it into my MB guy. You got any feedback on the 7 speed transmission?
